Would you build an EvilKey DIY kit?
4 hours ago • 0 commentsI am considering a complete DIY EvilKey kit based on the tested Waveshare ESP32-S3 Touch AMOLED 1.64 PCB V1, including a physical printed enclosure and a guide to assembly, flashing and testing. I am also considering a separately sold printable enclosure file for people who already own the board or prefer to print their own case.
Before defining the kit or accepting any orders, I would like to understand what would make it useful and realistic for builders. Please leave a comment with any of the following answers:
- Would you be interested in building it? Yes / Maybe / No.
- Do you already own the Waveshare PCB V1? Yes / No / Unsure.
- Which option fits you: complete kit with a physical case / electronics-only kit plus a printable case file / printable case file only?
- What would you need in the box or in the instructions to assemble it confidently?
- Which country would it need to ship to, and what total kit price before shipping would you consider reasonable?
- Which feature matters most to you: FIDO2, on-device PIN entry, the touch UI, Air Mouse, USB Tool, or the ability to modify the firmware?
You can answer just the questions relevant to you. A brief comment such as
Yes; no board; kit without case + printable file; Germany; FIDO2 + Air Mouseis useful. Please do not post email addresses, shipping addresses or authentication data in the comments.This is an interest check, not a preorder, reservation or promise of a sale. The exact contents, price, supported board revisions, fulfillment countries and launch date remain undecided. Any future listing will link back to the source and assembly instructions at https://github.com/mwr666/EvilKey-firmware.
One display, three USB roles: how EvilKey keeps the controls responsive
4 hours ago • 0 commentsThe EvilKey prototype uses Waveshare's ESP32-S3 Touch AMOLED 1.64 PCB V1. Its compact board already combines a 280 × 456 touch AMOLED, native USB, a QMI8658C motion sensor and a microSD slot. That made it possible to build an interactive key without adding a separate motion sensor or external display controller. Waveshare also sells a V2 revision with different pin assignments, so the current firmware target is explicitly V1.
The user interface was designed around short, readable screens and touch regions large enough to operate while holding the device. For display performance, the firmware tries to allocate two 64-row RGB565 draw buffers in DMA-capable internal memory and places the LVGL object pool in PSRAM. The Diagnostics page reports the buffer arrangement that actually started, instead of assuming the preferred configuration was available.
The FIDO2 PIN screen is a functional part of that interface. For built-in user-verification requests, EvilKey accepts a configured numeric FIDO PIN on its own 3 × 4 touch keypad. Digits are masked; the screen shows retry count and timeout, while Backspace, Verify and Cancel remain large touch targets. The local check uses the existing PIN verifier and retry budget. Standard ClientPIN is still advertised because host-side setup and clients that do not use built-in UV need it. This avoids claiming that every login is host-PIN-free. The PIN flow notes explain the protocol scope. The interface preview is code-derived; a filmed demonstration of the final on-device PIN flow is still pending.
Air Mouse is an example of a mode that needs both hardware and interface design. On entry, it samples the QMI8658C to establish a neutral orientation. Tilt becomes a relative HID pointer with a shared radial dead zone, smoothing and fractional movement accumulation, so diagonal motion does not have to choose between horizontal and vertical movement. A large MOVE touch region acts as a hold-to-move clutch. The other touch regions remain available for click and scroll; on-device settings provide recalibration, sensitivity and vertical inversion.
USB roles are intentionally distinct. The Air Mouse role enumerates as a relative mouse; the USB Tool role is selected separately; FIDO is the normal role. USB Tool scripts require local selection and a press of RUN. This keeps the behavior inspectable and prevents a script from running merely because the device was connected.
![Diagram of EvilKey FIDO, Air Mouse and USB Tool roles]()
The three USB roles are selected separately. The diagram describes intended enumeration, not three modes active at once.
The current firmware passed a physical smoke test of Air Mouse controls and return to FIDO. Long-running drift, repeated reconnection and complete product qualification are still separate work. The repository records the exact scope of the tests and documents the source and firmware build: https://github.com/mwr666/EvilKey-firmware
Next I am gathering feedback on a possible DIY kit. The following project log asks what makers would actually want included, and whether they would print the enclosure themselves.
Michal Wojciechowski
