It is 50 years since the release of 8085 and tinyBASIC. Since I have some 8085 chips, I thought of making some simple and effective design.
There are many open source designs available online. Most of them uses many components which are not available now or having large area of board.
I was looking for something similar to Lee Hart's 1802 or Z80 design. I came across a similar design based on 8085 microprocessor.
The board having only six ICs. Out of which three are just simple logic ICs.
There are only three main components in the design. Microprocessor, 8kB RAM and 8kB ROM. The computer operates at 4.9152MHz using external crystal. So it is very easy to make.
The good thing about this design is it comes with circuit, layout and monitor program. It fits into a Altoids tin. Due to small available space, the board was designed in four layers. But signals uses only TOP and BOTTOM layers and the inner two layers used as power planes which simplifies easy routing.
The technical article was published in march 2019 Nuts and Volts magazine. The 8085 computer was sold as a kit and currently not available.
As we see it uses very few components.
The assembled board looks like above picture.
It comes with inbuilt monitor program and tinyBASIC 1.0 with some additional commands.
The memory map is very simple.
Hardware Memory Map:
0000H - 0EFFH EPROM: TINY BASIC
0F00H - 0FFFH EPROM: ALTAIR TURNKEY MONITOR
1000H - 1BFFH EPROM: 8085 MONITOR
1C00H - 1FFFH EPROM: unused
2000H - 3FFFH SRAM
4000H - 5FFFH unavailable
6000H - 7FFFH RESERVED (decoded with I/O)
8000H - FFFFH OPEN
I/O Map:
00H - 5FH unavailable
60H - 7FH external I/O port
80H - FFH unavailable
Input Port: 60H
Output Port: 61H
Serial interface: 2400 baud, 8N1, Flow control: None
Because of processing of the serial data, sending text files from
TeraTerm requires delays for character and lines. I found the following
settings very reliable:
Transmit delay =
50 msec/char
200 msec/line
I have tried all the monitor options and all of them works well without any major issues.
The original design uses 8kB EEPROM 28C64 for ROM space. But I have used 8kB NVRAM DS1225 in initial testing.
As any board testing, it started with "hello, world" program
ORG 2000H ;load and run from address 2000H
LXI D, MSG ; load message starting address in DE
CALL COUT ; send a char pointed out by DE
CALL MONI ; return to MONITOR. No RESET required
MSG DB 0DH,0AH,'hello, world\n',0AH,0
MONI EQU 1000H ; monitor start address
COUT EQU 1021H ; monitor routine
END
the above program makes use of inbuilt monitor function COUT to send a character over serial port . The assembled program downloaded into target using L command and Executed using G2000 command. The result is as below
The same program using TINY BASIC
PALO ALTAIDS TINY BASIC VER 1.0
OK
>PRINT "HELLO, WORLD!"
HELLO, WORLD!
The monitor program was assembled using A85 assembler which is available now and works with Windows 11.
MONITOR ADDRESS VECTORS
The ROM subroutine addresses below may be useful for writing programs
on the Altaids computer.
MONITOR JUMP ADDRESSES
1000 COLD Monitor cold start
1003 WARM Tiny BASIC warm start
MONITOR VECTORS TO USEFUL ROUTINES (ENTER WITH CALL OPCODE)
1006 COUT Output char in A to serial port
1009 CIN Input char from serial port to A
100C PRTWD Output H,L as 4 Hex digits to serial port
100F PRTBY Output the byte in A as 2 Hex digits to serial port
1012 GETWD Get Hex word from serial port, return in H,L
1015 GETBY Get Hex byte from serial port, return in A
1018 PIN Get byte from input port, return in A
101B POUT Send byte in A to output port
101E DSPREG Display registers (registers are restored upon return)
1021 PUTSTR Send null terminated string pointed to by DE to serial port
Sample Assembly Language program listing using A85 assembler.
; DEMO.ASM ; ; ALTAIDS computer demo ; based on Altair demo from Popular...Read more »
mit41301
Michael Möller
rogerdipaolo
agp.cooper
Nice project. Good luck!
