Negative voltage support
04/15/2017 at 18:52 • 0 commentsI decided to post it on instructables too, and while tinkering with the scope I ended up adding support to negative voltages and offset. Here's a pic of 120VAC input from the mains:
I've uploaded the new code and plan to properly update the instructions here later, but in the meantime, anyone interested is welcome to check the project there.
Vítor Barbosa
