With this companion your mouse will be able to perform fine and precise movement in drawing applications
The first working firmware is already working. There is room for improvement, though.
The whole code is available at github but the main components are here:
1. The keyboard is read with a small delay betwenn the changes in I/O direction and the reading
// Set P1=0, P0,P2 = inputs with pullup
pinMode(0, INPUT_PULLUP); // P0
pinMode(1, OUTPUT); // P1
digitalWrite(1, LOW);
pinMode(2, INPUT_PULLUP); // P2
DigiMouse.delay(1);
if (digitalRead(0) == 0) button_state |= (1 << 2); // Left
if (digitalRead(2) == 0) button_state |= (1 << 3); // Right
// Set P1=1, P0=0, P2 = input with pullup
pinMode(0, OUTPUT); // P0
digitalWrite(1, HIGH); // P1
digitalWrite(0, LOW);
// pinMode(2, INPUT_PULLUP); // P2 no change, still input
DigiMouse.delay(1);
if (digitalRead(2) == 0) button_state |= (1 << 0); // Up
// Set P1=1, P2=0, P0 = input with pullup
// digitalWrite(1,HIGH); // P1 no change from last state
pinMode(2, OUTPUT); // P2
digitalWrite(2, LOW);
DigiMouse.delay(1);
if (digitalRead(0) == 0) button_state |= (1 << 1); // Down
2. The readings are analyzed to detect changes from the last scan.
if (button_state != last_scan) {
last_scan = button_state;
3. The (former) useless combinations (UP+DOWN, LEFT+RIGHT) are disregarded and the sensitivity index is advanced or regressed when keys LEFT and RIGHT are held together and the keys UP or DOWN are pressed
// Eliminate useless sequences: L+R
if ( (button_state & 0x0c) ==0x0c ) {
// Do L+R Stuff
if ( (button_state & 1) && (fib_index < (MAX_FIB_INDEX-1)) ) fib_index++ ; // Up
if ( (button_state & 2) && (fib_index > 0 ) ) fib_index--; // Down
} else {
if (button_state & 4) DigiMouse.moveX(-fib_step[fib_index]); // Left
if (button_state & 8) DigiMouse.moveX( fib_step[fib_index]); // Right
// Eliminate useless sequences: U+D
if ( (button_state & 0x03) == 0x03 ) {
// Do U+D Stuff
fib_index = 0; // U+R reset fib index
} else {
if (button_state & 1) DigiMouse.moveY(-fib_step[fib_index]); // Up
if (button_state & 2) DigiMouse.moveY( fib_step[fib_index]); // Down
The sensitivity is increased/decreased according to a slice of a fibonacci sequence.
const uint8_t fib_step[MAX_FIB_INDEX]={ 1, 2, 3, 5, 8, 13 };
4. Finally a small delay is added as a primitive debouncing method
DigiMouse.delay(5);
So far that's all folks!!
The third of two options to connect the potentiometer is not use the potentiometer at all, instead use useless key combinations for instance
hold LEFT+RIGHT pressed at the same time then use UP and DOWN keys to select sensitivity. To make things more interesting use a fibonacci sequence for the sensitivity, I mean the steps will be
1, 2, 3, 5, 8
And the combination UP+DOWN to reset to 1, just in case one get lost in the size of the step.
Now let't get back to the bench and code like there's no tomorrow until the job is done!
The first thing that came to my mind to add a slider was to use a potentiometer in series with a 1K resistor.
Then I remembered that the ground is not available at the I/O header.....
This is bad... very bad.... It leaves me with only two options.
With 3 pins available it is possible to get 6 switches by charlieplexing. It is prone to ghosting, though.
Since one of the pins I have available (P2) is biased to ground I was able to get only 4 without ghosting.
On the table below Z represents input with a pullup.
Next challenge is to add a pot slider to this cauldron ans stir while spelling some witchery....
The Digispark is a cheap and easy board to build USB devices, but the original circuit suffers from some unlucky design choices:
The three issues above makes the life harder when you aim for a minimalist design like in the present project, but let's pour the cards on the table:
As for the resources:
And the limitations
Now the demands for this project
Easy Peasy!!
I am using four diodes for charlieplexing the switches. But I think I will change that because I need to add a slider pot to control sensitivity.
Charlieplexed keyboard ? now, that's a hack :-D
Are these diodes, not resistors ?
