Just released Visuino version 7_8_3_9 with VL53L0X Laser Ranger support and more...
08/29/2019 at 02:13 • 0 commentsJust released Visuino version 7_8_3_9
- A Completely Free Mode of Visuino now available for entry level users and students
- Added VL53L0X Laser Ranger component
- Added Texas Instruments ADS1100 self-calibrating Analog-to-Digital (A/D) converter component
- Added DHT12 Thermometer and Humidity sensor component
- Added M5Stack ENV Unit component
- Added Analog, Color, RGBW Color, Date/Time, Digital, Integer, Text, Char, Clock, and Unsigned Demux components
- Improved RemoteXY Graph design support
- Improved Controllino PLC RS485 support
- Improved Industrial Shields RS485 Serial
- Improved Text Memory Element
- Improved BME280 and BMP280 component
- Improved Nextion component
- Improved ESP32 support
- Improved Value Array component
- Reduced memory usage by the Serial channels
- Reduced memory usage by some of the components
- Some IDE stability improvements
Just released Visuino version 7_8_3_3 with initial M5 Stack Core support and more...
08/12/2019 at 21:18 • 0 commentsJust released Visuino version 7_8_3_3
- Brand new revolutionary code generation design producing extremely efficient low Flash/ROM and especially RAM usage - up to 90% less RAM usage by the generated code, and up to 60 % less Flash/ROM usage
- Up to 90% execution speed improvement by the generated code
- Added support for the M5 Stack Basic Core module
- Added initial support for the PLDuino PLC WiFi Module
- Significantly Improved RemoteXY mobile device remote support
- Improved ESP8266 and ESP32 SSL sockets
Updated version of the User Code Component , and Experimental Sub Design support are included in Visuino Pro available in the MeWe Community for you to download
Just released Visuino version 7_8_3_1 with Raspberry Pi, ESP32 Peguino, ESPCopter support and more...
07/26/2019 at 05:13 • 0 commentsJust released Visuino version 7_8_3_1
- Added initial Raspberry Pi support
- Added initial Peguino ESP32 Brick support
- Added support for ESPCopter
- Added support for Arduino Every
- Added NINA-B1 support
- Added support for Adafruit proportional fonts in the graphics
- Added Angled Line in the graphics
- Added support for Centered Rectangles in the graphics
- Added support for Text and Array in the Structure and Packet components
- Added CPU Time component
- Added RemoteXY mobile device remote support
- Added support for complex arrays
- Added support for Funduino Joystick Shield
- Added support for setting IP addresses during execution
- Added support BMP280 Temperature and Pressure sensor
- Improved ESP8266 and ESP32 sockets
- Added a large number of math, array operation, and text components
- A lot of IDE stability improvements
Updated version of the User Code Component , and Experimental Sub Design support are included in Visuino Pro available in the MeWe Community:
Released the latest Beta of the new completely redesigned Visuino with Raspberry Pi support!
06/30/2019 at 21:34 • 0 commentsFor the last 6 months I have been working hard on a brand new, revolutionary Visuino design!
The goal was to make Visuino generate better optimized code than even very experienced developer can do after spending weeks of manual optimizations!
For this I had to invent a number of new advanced coding techniques. They are difficult to use when manually writing code, but are perfectly suitable for automatic code generation :-)
The work took long months of writing and rewriting, experimenting different approaches, testing results, and at the end completely rewriting (few times :-( ) all Visuino libraries from scratch, as well as practically all of the code generation algorithms.
As result for moths I was not able to make new posts, videos, tutorials, articles, answer many of my e-mails or social media contacts :-( . I was completely obsessed with the goal of completing this gigantic, and complex task...
The results however were astonishing! In some cases the generated code used more than 90% less RAM! The code size also shrank considerably and executes few times faster!But I did not stop here. I also significantly enhanced the Visuino graphics, adding many new features, including graphics elements specifically designed to allow you to easily display gauges and clocks. I also added support for Adafruit type proportional fonts.
Many new components were also added, and new features were added to existing components.
I also added support for packet communication of Complex data, Text, and Array.
Number of shields ware added, including PLC-LAB from PLC-Expert.
Finally to top it off, I added support for a number of new controllers, including:- Peguino
- Arduino Nano Every
- MicroPLC from PLC-Expert
- ESPCopter
- A number of ESP32 boards with Displays from TTGO and others
Now the real surprize! In this version I also added experimental support for Raspberry Pi!
Yes from now on Visuino will support not only Arduino and other microcontrollers, but also Raspberry Pi!Here is a screenshot of the new Raspberry Pi board mapping:
In addition to all this, quite some work went into making the IDE more stable, and easier to use.
The Visuino will continue to be in Beta for another 2 weeks or so and as soon as we all are happy with its quality, I will release the new version officially :-)Happy Beta Testing everyone! -
Just released Visuino version 7_8_2_261 with Elegoo PenguinBot robot support and more...
10/17/2018 at 01:49 • 0 commentsJust released Visuino 7_8_2_261
- Added support for SparkFun ESP32 Thing
- Added support for Elegoo Penguin Bot
- Added support for stm32duino STM32F103C8 Blue Pill
- Added support for SSD1331 Color OLED Display
- Added support for Macetech RGB Shades
- Added support for Maiyout Serial MP3 Player (MY1690-12P/MY1690-16S)
- Added categorized selection for cotroller boards
- Added Filtering for component elements
- Improved Graphics Performance
- Reduced memory usage and improved speed by many of the graphics displays
- Improved Circuit Playground support
- Improved ESP32 BPI-bit support
- Improved support for the YahBoom Robot
- Improved EVIVE support
- Improved performance by some of the components
- Improved Motor Drivers Components
- Improved PLDuino support
- Improved Nextion Display support
Updated version of the User Code Component is included in Visuino Pro available in the G+ Community:
https://plus.google.com/communities/116125623808250792822
You can download it here:
Just released Visuino version 7_8_2_259 with YahBoom BBC micro:bit robot support
08/21/2018 at 05:06 • 0 commentsJust released Visuino 7_8_2_259
- Added YahBoom BBC micro:bit robot support
- Improved BBC micro:bit support
- Improved NeoPixels support for ESP32
- Reduced Memory Usage by most Motor Control components
- Reduced Memory Usage by the WiFi, Ethernet, and GPRS components
- Reduced memory usage by SPI SSD1306 Display
- Improved ST7735 Display implementation with reduced memory usage
- Improved PCA9685 PWM implementation
- Improved RGBW Ramp To Color component
- A numbed of Visuino IDE improvements
Updated version of the User Code Component is included in Visuino Proavailable in the G+ Community:
Just released Visuino version 7_8_2_258 with initial Banana PI BPI:Bit support
08/04/2018 at 17:54 • 0 commentsJust released Visuino 7_8_2_255
- Added initial support for Banana PI BPI:Bit
- Added Char Snapshot
- Added Digital To Char
- Improved Thermocouple MAX6675 support
- Improved MPU9250 support
- Improved support for Text Snapshot, Switches and Muxers
- Improved color info printing
- Improved ESP8266 support
- Improved HX711 support
- Improved MQTT support
- Improved Up/Down counter implementation
- Reduced memory usage by the FormattedTextElement
- Improved implementation of the unarry operation components
Here is also the updated Component Development SDK: https://plus.google.com/communities/116125623808250792822
Just released Visuino version 7_8_2_255 with built-in Live Help
07/12/2018 at 20:08 • 0 commentsJust released Visuino 7_8_2_255
- Improved Visuino IDE user interface
- Extended unregistered running period from 10 to 15 minutes
- Added live Online Help
- Added new Updates Notification
- Added "Array Insert Items", and "Array Replace Items At Index" components
- Added support for the DFRobot 5 Buttons LCD Shield
- Improved Maxim LED Controller support
- Improved Formatted Text support
- Improved Frequency Meter Component
- Improved DFRobot Serial MP3 Player support
- Improved DS1820 Thermometer support
Added support for Outputs for the User Code Component included in the Visuino Pro version available in the G+ Community
https://plus.google.com/communities/116125623808250792822Here is also the updated Component Development SDK:
https://plus.google.com/communities/116125623808250792822 -
Just released Visuino version 7_8_2_246 with chipKIT Max32 and BPI:uno32 support
05/06/2018 at 23:07 • 0 commentsJust released Visuino 7_8_2_246
- Added initial chipKIT Max32 support
- Added BPI:uno32 support
- Added PlayTone support for ESP32 Improved support for the text components on some of the platforms
The new User Code Component is included in the Visuino Pro version available in the G+ Community https://plus.google.com/communities/116125623808250792822
Just released version 7_8_2_229 with new Graphics implementation and EEPROM support
03/17/2018 at 20:21 • 0 commentsJust released Visuino 7_8_2_228
https://www.visuino.com
- Added EEPROM support
- Added ZS-042 RTC DS3231 + EEPROM module support
- Redesigned Graphics support to use significantly less memory
- Reduced memory usage by a number of SPI components
- Expanded support for GPIO modules
- Improved SD cards support
- Improved IS31FL3731 display support
- Improved Packet support
Added new experimental user code component in the Visuino Pro version available in the G+ Community
Updated version of the Visuino Component Development SDK is also available in the G+ Community and the Facebook Beta group:https://plus.google.com/communities/116125623808250792822
