Current specs:
- Atmel ARM M0+ 48MHz microcontroller (ATSAMD21G18A-AU)
- 30 amps continous, >80 amps peak (TPN3R704PLL1QCT-ND) (probably over-kill)
- Proper bridge drivers (LM5109BSD/NOPB) (may switch)
- 2 to 3S (6.6V to 12.6V)
- Current monitoring (with the ACS711KEXLT-31AB-T)
- Various control methods; PWM, I2C, Serial, USB, OneShot
- ~$10 BOM @1000
- 3.3V DC-DC converter
- 20mm x 43mm PCB
Colton Black
The Big One
Christopher Xu
lukasz.iwaszkiewicz
Rory
Hi, very nice project buddy, actually I intend to made modular ESC in way that controller + gate driver is separated from Mosfets pcb , hence I could increase module ampere by adding parallel Mosfet in the Mosfets pcb, I really appreciated to have your advise or if you know open HW/SW sources let me know
