Project completed
10/29/2017 at 16:42 • 0 commentsI moved component into a new version of the 3d case, printed last week.
I moved the USB charging circuit to top right (so you can play while charging) and added 2 more screws holding the bottom of the case and 1 on the top of the case.
It works but there is an issue with sound : left and right channel are kind of mixed, so it’s not really stereo.
Almost complete
09/30/2017 at 12:29 • 0 commentsThe project is almost finished. The case is closed, everything is connected, except top left & right buttons.
It is functional and kids are loving it.
However, there’s still room for improvement : battery holder are too thin, and buttons are a little flacky (the way they are hold is not optimal).
Mainly, it’s the case which need some adjustment. -
building an USB short cable & adding an audio potentiometer
09/16/2017 at 20:25 • 0 commentsThe audio circuit is here to adjust audio from Rasbperry Pi using a B503 potentiometer.
You can find the layout on that amazon comments from driftinge30. -
Building a case
07/09/2017 at 13:09 • 0 commentsI’m designing the box to be 3d printed.
Work is in progress on github : https://github.com/paulgreg/retropie-portable-gamegear/
