Meet the requirements
08/20/2014 at 12:28 • 0 comments- Video posted
- The link to the video added
- This is the 5th Project Log
- The system design documents: schematic - https://github.com/CrazyChip/dimmer/tree/master/schematic , diagram of the design - https://cdn.hackaday.io/images/5952821408308060049.png
- The repository of the Kicad project: https://github.com/CrazyChip/dimmer
- Licenses - everything under GPLv3
Video
08/20/2014 at 12:19 • 0 commentsYou can see the two channels in action with two halogen lamps.
Works:
- dimming control with analog inputs
Problems:
- no temperature control
- unable to fit in DIN box
Unfinished:
- Modbus
Hardware
08/20/2014 at 12:10 • 0 commentsThe prototype is ready for testing:
ZCD
08/20/2014 at 12:04 • 0 commentsThe original Zero Crossing Detector developed:
https://cdn.hackaday.io/images/5109501408535937213.jpg
The resistors limit a current and the diodes limit a voltage from the bridge. RC output filter reduces the noise from mains. Both outputs from RC filters must be connected to Atmega's comparator. Such schematic uses two pins of Atmega.
Schematic uploaded
08/18/2014 at 13:24 • 0 commentsI commited schematic, Kicad project and gerbers to Github. Block diagram created with Google docs. Looks good with transparent background ;)
