Block diagram:
- Zero Crossing Detector (ZCD) is needed to control dimming.
- Triacs as switching devices connected via optocouplers
- Atmega controls dimming
- Each triac can be controlled by voltage level on analog inputs (0..10V) or using the external controller
- Temperature sensor is also needed
CrazyChip
Alireza Noferesti
electronicsworkshops
kevarek
Hey there! Awesome project! Wish I had found that earlier :) I also built a dimmer: https://hackaday.io/project/7504-lolb ^^c
