Details can be found here:
16-bit computer system featuring a custom-designed CPU
Thanks for pointing this out. I reorganized my videos a while ago and I must have made a mistake. I'll sort it out tomorrow.
You're welcome John !
I can't wait to watch them :-)
I've updated the links. I'm not sure that they are the exact same videos though because I had deleted them by accident so I couldn't verify them.
Hello John.
I understand that you have finished the hardware : the 4 main CPU boards, plus additionnal I/O and video boards. Is that correct?
That's great. Contratulations!
Have you tested all the hardware?
I've seen also that you begin to write some PDF documentation on your website, and that you go on with the software part (assembler).
Do you plan to add new blog update, either here or on your blog? I would be happy to read that!
Thanks. It seems to be working very well. It can run a self-test continuously for hours without going wrong. There were some very annoying mechanical oversights and several very 'interesting' problems getting it to be stable. The I/O still needs some work, but the video is working. I am planning to update the blog but I am behind and have so much to write it will take a while. I have been working on the assembler because the original version is a quick and dirty one which is buggy and under featured. I hope I have time to do all the things I have in mind for LEO-1.
A quick video of the tower of boards happily blinking along would be nice!
Thanks. I haven't had time yet to write about my flip-dot project. If you'd like I can send you the schematics...? It's actually 32x16 (two 16x16 panels).
What a beautiful work !
BTW you can have a look at #Dot flippers :-) I'm curious about your 24×32 array...
Grant Giesbrecht
Keith
Reed Foster
Here are a few videos:
https://youtu.be/ftok5QBDIvo
https://youtu.be/pBxxLNo1fCM
