Tool to convert gCode to Makerbot binary format. Needs proper configuration in param.ini DISCLAIMER: I have only tested this on my Malyan M180 and have no idea if it works with Makerbot at all.
This is a patch for pcb-gcode to add the possibility to mill outlines in a defined number of slices and not just in one go to max depth. Please also override the settings folder.
