And a video of the finished unit running
Repair and Modding a Body Wand
MagicWand-V1.0a.inoSimple sketch to make the thing work.ino - 3.06 kB - 06/11/2017 at 03:10 |
Cut of the original POT/Switch from the original board, Isolated the connections and wired it to the Arduino using the switch part to select the mode and the pot to adjust the speed.
Pretty simple, Gut the original wand and remove the controller, motor etc.
Grind a flat/key on the shaft of the BLDC motor to slip in to the vibrator connector.
Machine up a holder that allows the BLDC motor to fit in where the old motor came from
This seems a awful lot of work - my wifes "hack" is simply to stretch a condom over it before use to stop it getting damaged ;)
