Bluetooth under microscope
07/16/2017 at 09:04 • 0 commentsAnother thing to put under test about these modules is the second wireless technology used for transmitting data wirelessly from modules to a base station. This is Bluetooth! Bluetooth is around many years and there are many peripherals for almost every device with silicon :) So there are as many attacks and vulnerabilities as well fixes to test
Xbee under microscope
07/16/2017 at 08:42 • 0 commentsNow I'm going forward next step which is trying to intercept communications between wireless modules and the base station they are connected. So for that I purchased a Wireless Development Board form NXP the USB-KW24D512 which has sniffing utility built in and can sniff Xbee packets by default. Also you can write your own wireless application for it and run it on its ARM M4 embedded processor.
Dimitris Andritsakis
