1Follow the steps in this Google Doc
This Google Doc guides you step-by-step through your first capture using BeagleLogic Standalone.
2Build the Board (or buy one!)
As the component count is large, it would be a better idea to get the board assembled or buy one than hand assemble it.
3Plug in the board to your PC
Also Install drivers for Ethernet over USB, if on Windows.
4Open http://beaglelogic.local:4000/
This opens the BeagleLogic web interface. Click the buttons and start sampling!
