13d Model
The sketchup files are in the attachments, you will need to modify based on your requirements
23d Print
The final sketchup file with your chassis should be 3d printed
3Code
https://github.com/saipraveend/Snapbot - This is the github repo for the testing code that was used to run the robot.
4Assembly
The neodymium magnets should be stuck onto the print and assemble the components.
saipraveen
