1How Robot Script Language Works
Describes how Robot Script Language Works by moving a robot arm to specific angle ranges:
2Linear Actuator - Lead Screw/Threaded Rod Design
Demonstrates the motion of a Linear Actuator that uses a threaded rod design:
3Robot App Script Example: TurnMotor instruction
Example of how Robot scripts work using the TurnMotor instruction:
4How to Connect Touch Sensors to an EthAccels
Video shows how to connect touch sensors to EthAccels:
5Touch Sensors in the Robot Kit - How to use
How to use Touch sensors with the Robot Kit:'
6Robot App Walk Through
7Rover Build Video
8Robot Arm Build Video
9Linear Actuator Build Video (Threaded Rod Design)
10Linear Actuator Build Video (Rack and Pinion Design)
Ted Huntington
