Example of simple sample without box
09/01/2017 at 10:11 • 0 commentsSimple sample without box is shown. It is usefull for adjustment and learinig purposes. And it work! Electronic components are mounter on a tray, the sensors are mounter on a plywood board.
Sandwich- like Sensor Board is constructed and tested
08/29/2017 at 19:18 • 0 commentsWe made a drawing of a palm and the sensors
We use plastic breadboard for upper and lower boards
1-
1 - Sensors, 2- Screws M5 (fasten sensors to the board), 3- Screws M4 (fasten sensors to the moving moving base, 5 - cable to ADC, 6- Moving base for fingers
1- Moving bases, 2- Ribbon Fabric rings, 3- plastic fastener
New sensor board is constracted
08/29/2017 at 09:43 • 0 commentsWe constucted new type of sensor board. The new sensor board is a sandwich with base breadboard, sensor layer and upper bearing breadboard. The description and drawings are in the new buildinstruction Build Instruction ver. 4.0
Instruction is added - how to assemble sensor board
08/23/2017 at 22:29 • 0 comments3 instruction items are added- how to assemble sensor board using plywood, plastic cutting board and closed sensor board.
English Monitor Program and English instruction added.
08/06/2017 at 21:46 • 0 commentsProgram for Windows Computer - DiffDyn4. Program is free shareware. It need no installation, just copy to writable disk and work. Instruction also is added - InstructionEng.pdf. Take a take.
Arduino Code for LED version is added
08/04/2017 at 00:08 • 0 commentsArduino Code for LED version is added to "Files" and GitHub.
Executable programm Visualizer for Win is added. The program need no installation, just copy all the directory to writable disc and work. Some buttons have russian titles, it will be in English soon.
Build instruction is added to "Files". -
New Step-by-Step build instruction is on git hub
07/28/2017 at 22:31 • 0 commentsNew Step-by-Step build instruction is on git hub
Step-by-Step instruction is on Git Hub from now
07/27/2017 at 22:12 • 0 commentsYou can download build instruction from github Download from here file BuildInstruction.pdf
Github docs are added
07/27/2017 at 11:32 • 0 commentsYou can download docs and programms from Github. The latest version
Content 2017 07 27
DifDin4_Uno_LCD_Engl00.JPG Device schematics in graphim view, english language titles and marks
DifDin4_Uno_LCD_Engl00.spl7 Device schematics in SPlan format, english language titles and marks
DifDinLCD.ino code for Arduino IDE. Device with LCD 2x16 Display. GNU Licence
t2.hex hex file for direct load to atmel atmega328pu microcontroller (in Arduino Nano), without boot sector README.md this file
https://github.com/DrOnkel/DifDin.git
The Project descripiton is done.
07/26/2017 at 10:50 • 0 commentsThe descripiton includes schemes, BoM, video,puctures, Arduino IDE code.
