Transport
08/20/2014 at 14:13 • 0 commentsAt the moment I really don't know how to transport the explosives safely, but I think I will have to construct a soft gripper to not accidentally making it explode while transporting it.
I will defenitly have to find out more about the way the most frequently used explosive devices are built and how they work if I don't want them to destroy the drone or, even worse kill someone.
Marking
08/20/2014 at 14:04 • 0 commentsThe markings should be obvious but they shouldn't cause the explosives to explode, I think spray paint would be fine to start with.
Nonetheless I also want the drone to mark the found explosives digitally, it should create a (of course freely available) online map by using GPS data and Wifi of them to warn the world.
Eventually an app could warn users nearby.
Radio Control
08/20/2014 at 13:47 • 0 commentsMaybe I'm going to realize this via ZigBee, however I've never worked with wireless transmission systems, although I'm pretty sure it should be easy to use, easy to replace/repair and not too expensive.
Metal detector
08/20/2014 at 13:37 • 1 commentSeems like this one:
http://dzlsevilgeniuslair.blogspot.dk/2013/07/diy-arduino-based-metal-detector.html
works well, so I will try to build a similar version.
I also think that postioning the metal detectors coil parallel to the ground should be done by a gimbal, but I will have to work it out more exactly..
