We offer the new construction of walking Robo Base, we use the 5-link mechanisms as foots for quadroped.
RoboAmbler is simpe open source stepping quadruped Robot walking base with 5-bar linkages
Sniffer4Footz00.inoNew version of Stepping code. It goes!ino - 3.02 kB - 05/06/2018 at 18:14 |
RoboAmblerVer_00.PDFIntroduction to Walking Robo Base construction.Adobe Portable Document Format - 269.62 kB - 05/01/2018 at 00:51 |
We change the algorythm of stepping, so that the center of mass is between the foots, and nowe RoboAmbler can walk almost without hamble.
We assemble the model and try to start the walking using powerbank.
It can walk, but it walk with a limp now. We are to calculate more precise algorythm of leg changing to avoid a limp.
We install Arduino Nano for Stepping conrol, MCU for IMU data calculation, and IMU imu 6050 invensense. We use Li-ion battery and DCDC converter to get 5 V from 3.7 -4.1 V from Li-ion.
Here is base schematics
We use 8 Tower S90 g servos, Servo Holders and metal construction set. We connect it together in a base. Bottom, profile and face views
