New Bechele 3 (software 2.0)
03/06/2024 at 17:11 • 0 commentsSoftware 2.0 (Bechele 3) has been published.
The bechele software is now hosted on github.
The latest version may be downloaded from github using the following link:
https://github.com/bechele/bechele
Alternatively you may download one of the ready prepared image files – THIS IS MY RECOMMENDATION – because installing all the prequisites is still not too easy.
SD Card Image files are available for RaspberryPi 1b, RaspberryPi 3b and OrangePi-PC
All available SD Card images you may find here – also you will find there a tar-gzipped archive of the project:
https://my.hidrive.com/share/pc-obnpvxa
To check the file integrity you may check against the SHA512 checksum files published on the image download page.
Please report whether on Github or via this page if you encounter any problem.
3D printable eye mechanics
02/14/2018 at 18:51 • 0 commentsMeanwhile I added a Project on Thingiverse.com about a 3D printable eye mechanics fpr puppets.
See: https://www.thingiverse.com/thing:2781756
These eye mechanics work seamlessly together with this project.
Now a Gamepad can be used as an input device
11/12/2017 at 16:36 • 0 commentsA new update has been released, that allows to use a gamepad as input/teaching device instead of the self made arduino based joystick. With Software 2.0 the Joystick support is already inherited.
