1Prepare vero board
A standard size vero board can be cut in half to make 2 digital IO nodes.
And I used a drill bit to cut the tracks. These are for the 9 pins that need to be re-routed as they are not used directly as IO pins (apart from the 1 UART pin that needs the pull up resistor added).
2Prepare the teensy & vero board
3Mount the teensy on the board
And add the pull-up resistors
4Add the terminal blocks
5Glue to the mount frame and solder to the ethernet board
