Building on my RPi Telegraph project, the Arduino Teletype translates characters to baudot code and drives a teletype.
This initial step is to drive a teletype with three test programs.
Program 1:
The first a program that exercises the teletype with a series of 'R's and 'Y's.. The reason for this test is that the R and Y have opposite byte codes. R is 01010 and Y is 10101.
Program 2:
The second program exercises the each letter and number by typing the following sentence:
"THE QUICK BROWN FOX JUMPS OVER THE LAZY DOG'S BACK 1234567890 TIMES"
Program 3:
The third program accepts characters over the serial connection and types them out. It tracks the number of characters and sends a <CR> and <LF> command before reaching the end of each line.
Next build will decode the teletype signals. The grander vision is to combine this project with my telegraph project and have the arduino translate between the two devices.
#include<Serial.h>
//Baudot lookup table
unsigned char lookup[] = {
' ', 'E', ' ', 'A', ' ', 'S', 'I', 'U',
'\n', 'D', 'R', 'J', 'N', 'F', 'C', 'K',
'T', 'Z', 'L', 'W', 'H', 'Y', 'P', 'Q',
'O', 'B', 'G', 0, 'M', 'X', 'V', 0,
' ', '3', '\n', '-', ' ', '`', '8', '7',
'\r', ' ', '4', '\'', ',', '!', ':', '(',
'5', '+', ')', '2', '$', '6', '0', '1',
'9', '?', '&', 0, '.', '/', ';', 0 };
const int RELAY_PIN = 4;
const int CHAR_DELAY = 22; //milliseconds
const int START_BIT_DELAY = 22; // milliseconds
const int STOP_BIT_DELAY = 44; // milliseconds
const int SPACE = 4;
const int F_SHIFT = 27;
const int L_SHIFT = 31;
const int CR = 8;
const int LF = 2;
boolean letters_on = true;
boolean print_debug = false;
/* transmits 5 bit integers */
void byte_send(int _byte){
send_start_bit();
// loop through all 5 bits and send a space for zero bits, and mark for one bits.
for(int _bit = 0; _bit < 5; _bit++){
switch (bitRead(_byte,_bit)) {
case 0:
Serial.print(0);
space();
break;
case 1:
Serial.print(1);
mark();
break;
} // end switch
} // end for loop
send_stop_bit();
} // end byte_send()
/* Lookup and decode characters before transmitting. */
void char_send(char letter){
char l = toupper(letter);
Serial.print("sending ");
Serial.print(l);
int idx = lookupChar(l);
Serial.print(" idx: ");
Serial.print(idx);
Serial.print(" Binary: ");
// check for offset
if (31 < idx){ // shift for figures
if (letters_on){
figure_shift();
idx = idx - 32;
} else { // shift for letters
if (false == letters_on){
letter_shift();
byte_send(idx);
Serial.println();
} // end char_send()
void letter_shift(){
Serial.print(" [L_SHIFT] ");
letters_on = true;
byte_send(L_SHIFT);
void figure_shift(){
Serial.print(" [F_SHIFT] ");
letters_on = false;
byte_send(F_SHIFT);
void cr(){ Serial.print(" <CR> "); byte_send(CR); }
void lf(){ Serial.print(" <LF>"); byte_send(LF); }
void send_start_bit(){
digitalWrite(RELAY_PIN, HIGH);
delay(START_BIT_DELAY);
void send_stop_bit(){
digitalWrite(RELAY_PIN, LOW);
delay(STOP_BIT_DELAY);
void mark(){
delay(CHAR_DELAY);
void space(){
delay(CHAR_DELAY);
int lookupChar(char letter){
if (' ' == letter){ return 4; }
for (int lookupIdx = 0; lookupIdx < sizeof(lookup); lookupIdx++){
if (letter == lookup[lookupIdx]){
return lookupIdx;
return 0;
void setup(){
Serial.begin(115200);
pinMode(RELAY_PIN, OUTPUT);
pinMode(5, OUTPUT);
void demo(){
cr();
lf();
letter_shift();
for (int i = 0; i < 34; i++){
char_send('R');
char_send('Y');
void demo2(){
int idx = 0;
char demo_string[] = "THE QUICK BROWN FOX JUMPED OVER THE LAZY DOG'S BACK 1234567890 TIMES";
cr();
lf();
letter_shift();
for (int i = 0; i < sizeof(demo_string); i++){
char_send(demo_string[i]);
void demo3(){
int cur = 0;
while (cur < 68) {
if (Serial.available() > 0) {
Serial.print(cur);
Serial.print(": ");
char_send(Serial.read());
cur++;
cr();
lf();
void loop() {
demo();
demo2();
//demo3();
Hooked up the relay in my 58V DC loop but Demo is giving me CL's with a <CR> in between instead of RY's. Demo2 gives me a garbled message. Both demos do give me a constant errornumous output. The serial monitor shows a correct translation. The Siemens T100 telex works correctly when used with receiver and converter (converter was taken out of the loop for this) Any ideas?
Thanks for this wonderful program. It got me started with Arduino, and best of all it has my Teletype Model 28 and Western Union 2-B humming nicely. Great job!
Awesome! glad to help. I'm working on another program for this project. Do you remember Eliza?
Hi, would love to try this project. But I wonder what kinda of current limeter PSU are you using?
