I have split up this build into 3 major sections for my Vector monitor. The deflection, the high voltage and the CRT. The deflection runs the CRT tubes yoke and controls the beam on the screen. It is comprised of 2 amplifiers and a spot kill circuit. The high voltage takes care of the anode, focus and misc voltages used to drive the crt. The crt is the gun driver circuit and the crt itself. This is the section that runs the crt guns.
Here are some links that inspired me.
http://www.e-basteln.de/asteroids/asteroids_monitor.html
http://www.jrok.com/xfer/xystuff/
Here are the schematics for the Amplifone and WG6100
A good write-up about how XY monitors work.
http://www.jmargolin.com/xy/xymon.htm
THIS IS THE LINK TO THE MODIFIED SCHEMATIC
This is the schematic for my deflection PCB with the TIP transistors.
The circuit outlined in the green box is what is on my pcb. For the small signal transistors I used 2n2222 and 2n3906 transistors.
fredkono
ClimbinElectronics
ElectroBoy
I have a 12" IBM monochrome VGA monitor. Would this be good for a vector display, or is the phosphor decay too fast? Since the horizontal is ~31kHz, I figured it would make a nice, high-bandwidth yoke and HOT for lots of on-screen vectors, but I'm not well-versed in CRT tech.
