tighter belts, and a bit more tuning.
02/22/2015 at 21:24 • 0 comments1:1 on the distance and time movement is working now.
jerkily moving around
02/22/2015 at 07:54 • 0 commentsupgraded the firmware in the smoothieboard, that took a few times, but all is well now.
there is too much slop in the belts, and none of the grbl/smoothie parameters are set but its working.
i ordered a bunch of slightly shorter belts from polybelt since the Y adjustment is at its limit and too much slop/backlash.
i'm just sending raw Gcode from eagle via telnet
pretty good progress for a Saturday. probably be a while before its lasering though, i have some other plans for it first.
first motor wired up
02/22/2015 at 02:37 • 0 commentswell colour me impressed with the smoothieboard, after a few odd starts on the windows drivers side it popped up, i wired up the motor drivers i'm using to the pins , switched on the network config ,rebooted and moved one of the axis along.
cat 5e was all i had lying around handy
a tad heath robinson
24V for now.
frame mostly assembled
02/21/2015 at 21:32 • 0 commentslightobject saturday shipped my drivers , once i realised the smoothieboard was not even gonna come close (without external drivers, and then i feel its a waste of a board). lightobect have been great to me so far.
rear section (doge and frame)
- i pulled off the front pulley so i could take the trucks off and put them together upside down, much easier
left side (no hackaday io i don't want list numbers)
same with left side.![]()
mounted with the laser head, don't forget to put this on before the trucks![]()
mounted , oh for flips sake HTML editor bugger off with your numbers.......![]()
- < O_o
motor mounted![]()
drivers
Si 25mm mirrors
in a box.ok belts to install, some alignment and wire up the motors.
putting the frame together
02/21/2015 at 19:45 • 0 commentsputting the frame together, just you get an idea of the scale of this, that's a full grown Irish wolfhound in the previous set.
i'm using the countersunk screws here, they're obvious since almost exactly the right amount and the small right angle brackets are countersunk
lower frame corners, other pieces for deciding orientation and build order.
truck
rear right, i'm going to mount the rear drive before the top tracks i think.
rear left
middle rear, there are larger holes on the bottom side, i'm making the assumption they are (and fedex arrives with some more parts) access holes to screw into the Y motor brackets. though there are two holes and 4 tapped holes on the bracket. the 6 tapped holes are on the rear. kinda feeling i should have put mount on first since i'm working on the floor, time to break out the awesome metal saw horses from OSH that were on sale.
enough of the chatter and back to the building.. -
more bits !
02/20/2015 at 05:32 • 1 comment![]()
this thing is huge , no idea where i'm going to put it. doge for scale
Ordering parts from McMaster Carr
03/08/2014 at 17:11 • 0 commentsI choose to do the packs, since it is all useful bits and pieces and no matter how many of those darn pack of nuts, bolts screws, etc i buy from HF etc i never have the right ones. These quantities are for individual part quantities, and not boxes. $293.50 before shipping and taxes, or about $69 if you buy in the actual part count.
1 pack 95475A572 Zinc-Plated Steel Fully Threaded Stud, 1/4"-20 Thread, 8" Length, packs of 10Monday morning $13.04 pack 13.04 2 pack
95475A576 Zinc-Plated Steel Fully Threaded Stud, 1/4"-20 Thread, 10" Length, packs of 5Monday morning 8.26 pack 8.26 3 pack
98055A099 Metric Spring Steel Shim - DIN 988, 1.0mm Thick, 5mm ID, 10mm OD, packs of 50Monday morning 8.62 pack 8.62 4 each
6061K31 Hardened Precision Steel Shaft, 1/4" Diameter, 12" LengthMonday morning 5.21 each 5.21 5 each
6061K415 Hardened Precision Steel Shaft, 1/4" Diameter, 14" LengthMonday morning 6.16 each 6.16 6 pack
9600K22 Push-in Grommet, 1/2" ID, 1" OD, 3/32" Thick for a 3/4" Diameter Panel Hole, packs of 50Monday morning 9.54 pack 9.54 7 4 each
62805K31 High-Cap Leveling Mount with Zinc-Plated Steel Stud, 10-24 x 1-1/2" Thread Length, 1-3/16" Base DiameterMonday morning 1.98 each 7.92 8 each
1764K42 Steel Angle Ring with 6 Holes, 4" Duct Diameter, 9/32" HoleMonday morning 4.31 each 4.31 9 pack
91420A320 Metric Flat Head Phillips Machine Screw, Zinc-Plated Steel, M5 Size, 10mm Length, .8mm Pitch, packs of 100Monday morning 4.05 pack 4.05 10 pack
96659A101 18-8 Stainless Steel Type A SAE Flat Washer, Number 4 Screw Size, 5/16" OD, .02"-.04" Thick, packs of 100Monday morning 2.96 pack 2.96 11 pack 97416A115 Black-Oxide Steel Type A SAE Flat Washer, Number 10 Screw Size, 1/2" OD, .03"-.07" Thick, packs of 100Monday morning 3.82 pack 3.82 12 pack
90631A003 Zinc-Plated Grade 2 Steel Nylon-Insert Hex Locknut, 2-56 Thread Size, 1/4" Width, 9/64" Height, packs of 100Monday morning 3.45 pack 3.45 13 pack
90631A005 Zinc-Plated Grade 2 Steel Nylon-Insert Hex Locknut, 4-40 Thread Size, 1/4" Width, 9/64" Height, packs of 100Monday morning 2.55 pack 2.55 14 pack
90257A411 Type 316 Stainless Steel Machine Screw Hex Nut, 10-32 Thread Size, 3/8" Width, 1/8" Height, packs of 100Monday morning 9.00 pack 9.00 15 pack
94945A205 Grade 8 Steel Nylon-Insert Thin Hex Locknut, Zinc-Yellow Plated, 1/4"-20 Thread Size, 7/16" Wide, 13/64" High, packs of 100Monday morning 6.70 pack 6.70 16 pack
90576A104 Metric Zinc-Plated Steel Nylon-Insert Locknut, Class 8, M5 Size, .8mm Pitch, 8mm Width, 5mm Height, packs of 100Monday morning 4.18 pack 4.18 17 pack
91772A082 18-8 Stainless Steel Pan Head Phillips Machine Screw, 2-56 Thread, 5/8" Length, packs of 100Monday morning 4.15 pack 4.15 18 pack
90402A146 Zinc-Plated Steel Pan Head Phillips Machine Screw, External Washer, 6-32 Thread, 3/8" Length, packs of 100Monday morning 6.95 pack 6.95 19 pack
92000A118 18-8 Stainless Steel Metric Pan Head Phillips Machine Screw, M3 Size, 8mm Length, .5mm Pitch, packs of 100Monday morning 4.66 pack 4.66 20 pack
92000A120 18-8 Stainless Steel Metric Pan Head Phillips Machine Screw, M3 Size, 10mm Length, .5mm Pitch, packs of 100Monday morning 4.34 pack 4.34 21 pack
97334A992 Nylon Socket Head Cap Screw, 10-32 Thread, 1" Length, Black, packs of 100Monday morning 6.41 pack 6.41 22 pack
91290A130 Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M3 Thread, 30mm Length, 0.50mm Pitch, packs of 100Monday morning 14.41 pack 14.41 23 2 packs
91290A224 Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 10mm Length, 0.80mm Pitch, packs of 100Monday morning 9.41 pack 18.82 24 pack
91290A228 Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 12mm Length, 0.80mm Pitch, packs of 100Monday morning 10.81 pack 10.81 25 pack
91290A230 Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 14mm Length, 0.80mm Pitch, packs of 100Monday morning 11.52 pack 11.52 26 pack
91290A252 Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 25mm Length, 0.80mm Pitch, packs of 50Monday morning 7.24 pack 7.24 27 pack
91290A254 Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 30mm Length, 0.80mm Pitch, packs of 50Monday morning 7.87 pack 7.87 28 pack
91290A256 Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 35mm Length, 0.80mm Pitch, packs of 50Monday morning 9.67 pack 9.67 29 pack
91290A260 Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 45mm Length, 0.80mm Pitch, packs of 50Monday morning 11.24 pack 11.24 30 pack
92146A005 18-8 Stainless Steel Split Lock Washer, Number 4 Screw Size, .21" OD, .02" min Thick, packs of 1000Monday morning 5.22 pack 5.22 31 pack
92146A011 18-8 Stainless Steel Split Lock Washer, Number 10 Screw Size, .34" OD, .04" min Thick, packs of 1000Monday morning 11.14 pack 11.14 32 pack
94785A411 18-8 Stainless Steel Square Nut, 10-32 Thread Size, 3/8" Width, 1/8" Height, packs of 100Monday morning 8.73 pack 8.73 33 pack
94639A208 Nylon Unthreaded Spacer, 1/4" OD, 7/8" Length, #4 Screw Size, packs of 100Monday morning 9.35 pack 9.35 34 pack
94639A350 Nylon Unthreaded Spacer, 5/16" OD, 1/8" Length, #10 Screw Size, packs of 100Monday morning 7.04 pack 7.04 35 pack
94639A352 Nylon Unthreaded Spacer, 5/16" OD, 1/4" Length, #10 Screw Size, packs of 100Monday morning 7.45 pack 7.45 36 pack
94639A454 Nylon Unthreaded Spacer, 3/8" OD, 3/8" Length, #10 Screw Size, packs of 100Monday morning 8.05 pack 8.05 37 pack
94639A450 Nylon Unthreaded Spacer, 3/8" OD, 7/8" Length, #10 Screw Size, packs of 100Monday morning 9.64 pack 9.64 38 pack
91770A096 18-8 Stainless Steel Truss Head Phillips Machine Screw, 4-40 Thread, 1/2" Length, packs of 100Monday morning 4.70 pack 4.70 39 pack
91770A144 18-8 Stainless Steel Truss Head Phillips Machine Screw, 6-32 Thread, 1/4" Length, packs of 100Monday morning 4.35 pack -
parts ordered from misumi (and delivered)
03/05/2014 at 18:33 • 0 commentsA few days ago i ordered parts for part of the frame from misumi, they have a special going on where I could get $150 off the first order.
The details of the discount are here, I accidentally used First150--Reddit, but that is not the right code, since they have it for a specific set of parts for a 3d Printer.
"To receive the $150.00 Credit, companies must place their first order online using a Credit Card and include promotion code "First150--BuildLog" in the "Special Instructions" of the order. Offer is based only on the value of the goods purchased; freight and handling charges are excluded. The full value of the $150.00 credit must be used on the first order, no promotional credit balance will carried forward. Offer expires March 31, 2014. Available in US and Canada only."
Details are here.
http://www.buildlog.net/forum/viewtopic.php?f=2&t=2445&p=21864
Sorry about the funky layout, i copied it off the order I made, you should double check with the Buildlog BOM, because if i did make any mistakes i won't know til i start assembling it.
Line Item
Name
Part number
Description
Quantity
Item Cost
Total Cost
------------------------------ -------- 1
CAST CORNER BRACKET
HBLFSN5
Assembly Brackets Slot Width 6
45
0.75
33.75
2
THIN BRACKET, 1 WIDE
HBLSS5
2
1.02
2.04
3
THIN CORNER BRACKET
HBLTS5
2
1.10
2.20
4
EXTRUSION 2020 160MM LG.
HFS5-2020-160
ALUMINUM FRAME
1
3.03
3.03
5
EXTRUSION 2020 230MM LG.
HFS5-2020-230
ALUMINUM FRAME
1
3.03
3.03
6
EXTRUSION 2020 310MM LG.
HFS5-2020-310
ALUMINUM FRAME
4
1.76
7.04------------------------------
7
EXTRUSION 2020 370MM LG.
HFS5-2020-370
ALUMINUM FRAME
2
2.10
4.20
8
EXTRUSION 2020 440MM LG.
HFS5-2020-440
ALUMINUM FRAME
2
2.50
5.00
9
EXTRUSION 2020 560MM LG.
HFS5-2020-560
ALUMINUM FRAME
7
3.19
22.33
10
EXTRUSION 2020 580MM LG.
HFS5-2020-580
ALUMINUM FRAME
2
3.30
6.60
11
EXTRUSION 2020 725MM LG.
HFS5-2020-725
ALUMINUM FRAME
2
4.13
8.26
12
EXTRUSION 2020 728MM LG.
HFS5-2020-728
ALUMINUM FRAME
1
4.14
4.14
13
EXTRUSION 2020 730MM LG.
HFS5-2020-730
ALUMINUM FRAME
3
4.16
12.48
14
EXTRUSION 2020 90MM LG.
HFS5-2020-90
ALUMINUM FRAME
1
3.03
3.03
15
EXTRUSION 2020 960MM LG.
HFS5-2020-960
ALUMINUM FRAME
3
5.47
16.41
16
EXTRUSION 2040 960MM LG.
HFS5-2040-960
ALUMINUM FRAME
2
10.36
20.72
17
HINGE - LEFT
SHHPSL5-2
Detachable Hinges
1
7.31
7.31
18
HINGE - RIGHT
SHHPSR5-2
STAINLESS SLIP JOINT HINGES
1
7.31
7.31
03/03/2014
19
M5 T-SLOT NUT
HNKK5-5
NUTS FOR ALUMINIUM FRAMES
1
19.32
19.32
20
POST ASSEMBLY NUT
HNTP5-5
NUTS FOR ALUMINUM FRAME
10
0.58
5.80
charliex
in a box.
