NeuroBeast v2 springy feet, ready to accept shoes. Use PLA, 0.2mm layer height, 20% infill, no supports or raft. Released under the terms of the GPL v3, as detailed in the LICENSE file.
Standard Tesselated Geometry -
246.37 kB -
05/27/2016 at 16:37
NeuroBeast v2 8-legged chassis *.stl file for printing. Use PLA, 0.2mm layer height, 20% infill, no supports or raft. Cams will likely need a bit of trimming to work reliably. Released under the terms of the GPL v3, as detailed in the LICENSE file.
712.97 kB -
05/27/2016 at 16:37
