Finished painting the set
01/26/2018 at 13:58 • 6 commentsI've decided on using the edding 4200 series on this run. I had to go over twice to get a good covering. Next time I'll try nailpolish though, since the color is still removable with Isopropanol, but tougher than with the 300 series.
LED choice
01/15/2018 at 12:37 • 0 commentsI'm currently deciding between 3mm / straw hat / 5mm LEDs and whether the animation should be slow or fast. I could only find 5mm RGB flashers that are diffused, but it would be so cool to have the other ones diffused as well. So I've ordered a bunch (way too many) LEDs and hope they'll arrive soon.
doing a science
01/15/2018 at 09:42 • 0 commentsGoing to use some Edding pens to see what I can do about "multicolored" stencils
davedarko
