3D scanner
Takes 3D surface scans at close range. It is simple to construct as it uses off the shelf hardware and software.
The scanner performs instant capture of a 3D surface, and after some (fully automated) processing, outputs a 3D model that can be viewed in CAD packages for measurement, or re-printing etc.
The key components are:
a) 4 cameras (to capture the object from different angles).
b) A Multi-view Stereo (MVS) algorithm which turns the 4 images into a 3D model.
c) A projector which projects a random pattern onto the object to help step b.
4 Raspberry Pi Zero's perform synchronised capture and upload images to the cloud ready for processing. A more powerful laptop takes over to create a nicely smoothed, textured mesh.
Essentially, MVS finds matching features in each of the images so that it can triangulate distance. Projecting extra features onto the object results in a more accurate 3D mesh.
It was only designed to capture 3D surfaces at about 6 inches (disregarding the rear of the object and so on), but speed, simplicity and accuracy for this task all score highly.
View project log
Rich text editor
Manfred wrote 02/13/2018 at 02:23 point
I don’t suppose there is a similar way to digitize buildings, without needing the random dot patterns?
Also, why does the data from the Pi Zeros have to go to the “cloud”? Surely any recent PC can handle the work.
malvasio wrote 02/13/2018 at 07:23 point
with rpi3's the 'cloud' should be avoided
reodds wrote 01/25/2018 at 18:14 point
@Jolar, we'd all like the build details for this project.  Would you please add them?  Thanks!
zippy123 wrote 01/24/2018 at 22:28 point
Do you have any details on this?
Neon22 wrote 01/17/2018 at 22:16 point
A good source of scatted random dot pattern is a laser bounced off a dull white slightly curved surface. We used an Aspirin for a similar project in the 90's. very efficient, cheap.
ekaggrat singh kalsi wrote 01/17/2018 at 22:06 point
great work. I always wondered why structured light scanning could not be done with a rudimentary laser with a projection pattern. The pattern can be a rotating disk with cutouts or something like that. I can wait to see the scripts published.
froitu wrote 01/23/2018 at 10:29 point
Actually, David Laser Scanners does it. Structural images they chose are mainly horizontal & vertical stripes. https://www.youtube.com/watch?v=1ptq9I-DT3I
Robert Mateja wrote 01/17/2018 at 21:48 point
The question I have, Is that mesh straight from scanner or it was post-processed? I had similar results with one camera and Agisoft but with A LOT of pictures and some post.
Jolar wrote 01/21/2018 at 22:47 point
I'm not too familiar with Agisoft but in my experience the pattern projection helps more than the number of images.  In the example image the only post processing was to crop the 3D model to show the central region where the hand is.
Mike Szczys wrote 01/17/2018 at 15:43 point
I can't wait to see more details on the project. You're getting a really great outcome with clever use of rather rudimentary hardware, impressive!
froitu wrote 01/23/2018 at 10:31 point
I am really looking forward for more details too about this. Perhaps I'll even build one if details arrived.
Lee Cook wrote 01/17/2018 at 12:15 point
I love it.
If you projected 3 patterns (say random Red, Green and Blue patterns) from different projectors at different angles would that help with the creation of the 3D image?
By 'projectors' I'm thinking something simple like:
http://www.kmhpromo.com/custom_projector_pen/projector_keychain.html
thygate wrote 01/17/2018 at 16:49 point
you're thinking of structured light scanning, this is photogrammetry.
Also i have my doubts with the claim that this is fully automated. VisualSFM outputs point clouds , and surface reconstruction on meshlab usually requires a lot of manual cleaning before a decent mesh can be obtained.
Lee Cook wrote 01/17/2018 at 18:15 point
No, the thinking behind it was that with a single projector you're only going to be able to add features to a single "face".
With multiple projectors (so long as they don't wash-out areas that are already lit - hence the three colours) you would be able to give features to surfaces which multiple cameras could see, but a single projector could not reach.
Jolar wrote 01/21/2018 at 22:49 point
Regarding "fully automated" what I meant by this is that from a click of the button a 3D mesh arrives on the laptop screen.  In the example image I did crop the scan to make it a nice rectangle but there was no manual processing or tidying of the 3D hand.
Jolar wrote 01/21/2018 at 22:36 point
I like those ideas.  I used a digital projector so I could experiment easily with different pattern projections - its a major factor in the accuracy.
