The finished project should mill PCB's and laser etch materials like leather. The goal for the workingarea is 400 mm * 400 mm at least.
Homemade X/Y-Table to mill PCBs and etch materials like leather with a Laser
Mounted the linear rails for the Z-axis:
Mounted the Z-axis ballscrews:
The entire system:
The next step is to mount a big plate on the ballscrews and the linear shafts.
Now the Motors for the X-Axis are mounted outside, so the Working-Area gets bigger.
I've added a small Z-axis out of an old DVD-Drive and hoocked it uf to my CNC. At the z-axis i mounted a pen, so now my machine can plot pictures on a Paper or flat surfaces like my "Sprit" or alcohol bottle.
Here is the first test-video of my CNC, in this Video, i couln't controll the laser, but at the moment it works. This is a normal violet laser who writes on a glow in the dark surface.
Here is the Video: http://youtu.be/Xan15t2EbFY
Now the Y-axis is added to my PCB-Mill and the belts arrived so i dont't have to use those
First Test of the X-axis was succesfull. The axis don't have a belt at the moment, because they didn't arrived at time, but a sholace will works fine ; ). Next step is to Design the new holder for the y-axis linear shafts, with a included beltholder.
hi everyone who is following this project.
If one of you would like 2.1W, 3.5W and 5.6W lasers EnduranceLasers.com would be happy to give you 10% off for them, just give us a promo code "Hackaday"
Thomas
hebel23
Paul McClay
joekutz
please add a tutorial on how to make it.
