About 3 months ago I got this new friend, his name is Scorbot. Scorbot was rescued from a junk yard by my friend, bought it for 20USD and brought it to our group for analysis. A quick check on Ebay showed that this type of robotic arm is sold for 300USD minimum! Adding the fact that it was very rusty and filthy and the conclusion was pretty much obvious - Scorbot is probably not gonna work. Well, if I'm writing this post that's probably not what happened. I've built Scorbot a controller, using an Arduino MEGA, to control its motors and get data from its encoders and microswitches. For the full description and code:
http://www.whatimade.today/my-name-is-scorbot/
amigo tengo un escorbot igual a tu proyecto estoy atorado en el encoder cuantas vueltas da el disco del encoder por un grado espero y me puedas ayudar por favor
Hi! I think the best way to make a conversation about the post is via the blogs' comments. If I wrote something which is not clear it is most likely you will not be the only one asking those questions :) - Just scroll down to to the bottom of the blog there's a comment section. If you prefer to discuss privately let me know and send me your email with a private message.About the 50 pins connector - Got it on ebay like all other items. Here's a link for example:http://www.ebay.com/itm/Audio-Video-DB50-50Pin-D-sub-Solder-Type-Female-Plug-Connector-Adapter-/390902034280?pt=LH_DefaultDomain_3&hash=item5b0393af68
Hello, can you reup the link to your project. I click the yellow link but it was crashed, thank you very much.
