My PCB-Motor is made from a 6-pole stator printed on a 4-layer PCB and a 4-pole 3d printed rotor. Its has an outer diameter of 16mm and is rated at 1 watt.
I had this idea when I was trying to design a small compact drone. The PCB motor is much cheaper than other micro brushless motors and also easier to assemble. My goal is to make the rotor part of the BOM and mounted just like any other component on a PCB.
VIDEO
HACKADAY SUPERCON DEMO
Carl Bugeja
Mrinnovative
Arnov Sharma
ebaera
Hello Carl. Congratulations on your excellent work! Please let us know if you plan to sell your motors. I like the idea of putting the stator on the ESC PCB.
