Cached Site
11/07/2019 at 12:35 • 0 commentsThere's now a static cache of the now defunct subpos.org and wiki. Please note that some links between the main site and the wiki site are broken, but if you go to them directly using the links below they work fine.
Also note. The search bars still link to the subpos.org domain, which is no longer controlled by SubPos. Any results you receive by using the search functions on either the wiki site or the main site are not endorsed by SubPos.
Browse the main site with the following link - https://subpos.github.io/
Browse the wiki site with the following link - https://subpos.github.io/wiki/index.php/SubPos.html
It's in the repo if you want to clone and browse locally - https://github.com/subpos/subpos.github.io
Ranger Kickstarter Now Live
07/07/2016 at 03:45 • 0 commentsSo after many hours of sleepless coffee fueled crazy times, a surprise Kickstarter campaign for the Ranger is now live!
https://www.kickstarter.com/projects/subpos/subpos-ranger-indoor-positioning-system
Ranger Demo
07/05/2016 at 14:40 • 0 commentsOver on the SubPos Ranger project page I have a demo up and running:
The client is connected to the laptop with a USB connection. However, the client does all the positioning calculations, the laptop is just displaying the node positions and the current client position.
Averaging is turned right up which is why it takes a little while to update the position. This is because I live in an apartment block with lots of 2.4GHz RF flying about, so this helps to cope with that. I am integrating an accelerometer on the client to provide better intemediate updates when averaging is turned up too. But as you can see, it's pretty spot on in terms of accuracy. -
More Ranger
05/24/2016 at 01:09 • 0 commentsA few things have been happening over on the SubPos Ranger project page. I now have Rev.02 modules and clients built:
SubPos Ranger Project
03/05/2016 at 23:55 • 0 commentsNote that there are some updates happening on the SubPos Ranger project page. I currently have a Ranger Node built, ready for testing:
SubPos Receiver
01/31/2016 at 10:17 • 0 comments![]()
I have released the sources for a receiver module which works with the ESP module - https://github.com/subpos/subpos_receiver
It's been tested on Arduino and the Teensy 3.2 as well as Energia and the Launchpad Tiva C (tm4c123).
For use with the ESP Wi-Fi Scanner Firmware - https://github.com/subpos/esp_wifi_scanner
New Project Page
01/19/2016 at 07:35 • 0 commentsFuture updates for the ranging system (SubPos Ranger) will be placed in the new project page - https://hackaday.io/project/9242-subpos-ranger
Please skull and follow this project for ranging updates.
ESP Module v2 Firmware
01/15/2016 at 03:11 • 0 commentsHere is a newer version of the ESP firmware that now utilises the wifi_send_pkt_freedom() function to send beacon frames.
https://github.com/subpos/esp_firmware_v2.git
This method of generation allows for tighter control of beacon frame rates and increases security as it runs in a passive client mode and only generates beacon frames.
Note that the Node firmware has also been updated to support this new version. You will need to use the latest Node firmware (0.1.6) with this firmware. Additionally, the old ESP firmware will not work with the latest Node firmware.
Just a Teaser
12/03/2015 at 04:45 • 0 commentsHere is a little teaser of the AT86RF233 dev modules that I will be working with to perform a simple method for ranging (distance) calculations:
Error Circles and New Website
11/12/2015 at 11:56 • 0 commentsI now have standard deviation error circles working to display the calculated positional error. It shows the possible circle error from all the positioning measurements (i.e., the client could be located anywhere in this circle):
This value calculated is the radius of the circle surrounding the position as the center point (the developer just has to draw the circle from this radius). This is updated in the Android API repository on GitHub.
I also have a fancy new website (the wiki is still there as a link) at http://www.subpos.org :
Blair Wyatt
