Renault JE wheel bearing cap
My parents lost the bearing cap on their car. Our car service station couldn't get the part because the car is to old...
So i made the part
This is an enter for a Student Project.
I made the wheel bearing cap for the Renault Espace III (Type JE). The original part had a big crack in it.
Our local service station couldn't get the part because the car is to old. So i measured the cap on the other wheel and printed a new one.
The part is printed in flexible filament.
The main purpose of this cap is to keep the grease on and in the wheel bearings. This protects it from water and rusting. Bearings love grease :)
If you want to do that you need some thick grease. Preferably bearing grease. And use a lot.
More grease = more better.
The cap now holds up for the 3rd week of daily use and will probably hold up for much longer
My parents used tape to seal everything.  It worked too, but a new cap is a much cleaner solution.
Renault JE wheel bearing cap.pdf
Measurements of the model
Adobe Portable Document Format - 42.10 kB - 02/09/2018 at 15:31
Preview
Renault JE wheel bearing cap.stl
.stl file for 3D printing
Standard Tesselated Geometry - 4.46 MB - 02/09/2018 at 15:31
Download
  • 1
    Printing and inserting the the cap
    You can print this without supports. I used flexible filament (TPU) to print the cap. This prevents the hooks from snapping off when you insert the cap. Use a ton of grease. The cap on the other side was full of it.
View all instructions
3ahmad-re wrote 07/19/2021 at 18:21 point
Looks good. Can I modify this Grease model for my grease trap to make it faster?
lothar-knopp wrote 02/09/2018 at 20:21 point
Works perfect in my car !
