More de-coupling
09/25/2015 at 16:00 • 0 commentsAs everything was connected up and the power was switched on there was a faint whine coming from somewhere in the circuit. I figured the Numitrons were causing some power fluctuations so I added a 100uF capacitor on the power rail. The whining stopped.
The power supply module I have already has capacitors but they didn't seem to help here.
Rotary encoder
09/23/2015 at 05:32 • 0 commentsThe first prototype had a potentiometer which acted as a selector between the clock's different view modes. I replaced that with a rotary encoder as it has unlimited range and avoid the potentiometer's unwanted behaviour of hovering between two states.
Numitron adapters
09/16/2015 at 18:10 • 0 commentsSoldered the numitrons to separate boards with small screw connectors. This should make connecting them a bit easier and also make replacing a tube possible in case a filament burns out.
Field telephone
04/11/2015 at 13:11 • 0 commentsReceived the field telephone and it looks like a good fit for the Numitrons and the electronics. As it's military hardware it's very easy to dismantle without breaking anything. I'll just remove everything except the case itself and make a new top which houses the tubes.
Possible casing
04/07/2015 at 17:52 • 0 commentsInstead of doing some woodworking I decided to try to make the casing out of an old field telephone. Its bakelite housing should make a really nice-looking retro case with some modifications.
