Hololens Repair Notch Cutter.stl
Print this piece to use as a guide to cut notches into the strap
Standard Tesselated Geometry -
12.19 kB -
02/13/2018 at 19:49
Download
Hololens Repair A with Notch.stl
Notch method, outside bracket (away from wearer's head)
81.53 kB -
02/13/2018 at 19:49
Download
Hololens Repair A with Pin.stl
Pin method, outside bracket (away from wearer's head)
88.17 kB -
02/13/2018 at 19:49
Download
Hololens Repair Hole Punch Guide.stl
Print this piece to use as a guide to drill or punch a hole into the strap
19.61 kB -
02/13/2018 at 19:49
Download
Hololens Repair B with Notch.stl
Notch method, inside bracket (next to wearer's head)
58.68 kB -
02/13/2018 at 19:49
Download
Hololens Repair B with Pin.stl
Pin method, inside bracket (next to wearer's head)
83.97 kB -
02/13/2018 at 19:49
Download
