1Select method of repair: Notch Method or Pin Method
If you wish to repair the band by cutting notches in the side, print the Notch Cutter. If you would rather drill a hole through the band through which you would insert a pin, print the Hole Punch Guide.
2Cut or drill your broken band
Slide the band into the guide and cut or drill. The photo below shows the notch method so the band must be cut.
3Print Bracket to match Repair Method
Print with at least 100% infill for maximum sturdiness. Supports may be required for some printers.
4Slide strap and band into the bracket and snap clasps down
Place Side A in place first. Make sure the notches or pin hole is lined up properly. Then press Side B in place and make sure all four clasps snap together..
Ryan
