Almost done
10/18/2015 at 11:37 • 0 commentsAnd after quite a long break another step closer to the finish.
I've taken my chances of destroying the panel and front USB socket is almost ready.
Templatewas done using Inkscape, wires visible on picture are for better positioning- they were placed in original holes (used to attach producer's logo). They are not perfectly positioned because my printer scaled the image down.After drilling 3mm holes I've attached a much stronger (and better) template
Old USB bracket was just perfect to cut out the hole withouth the riskof cutting too much in any direction. Adjustemets were done using a
small flat file. Also I had to make room for the USB socket behind the
front panel.
The last thing left to do is to fill all unnecessary holes in the panel and paint it.Also I've updated PowerCtrl code- now it remembers last light state change, timer will be resetted only if Odroid's led did a full cycle (on and off). This way it should disable
power also when for any reason blue led lights a solid light. Code is available on Github (now with a proper GPL attached).
Front panel and test run
05/07/2015 at 14:20 • 0 commentsWorks on the front panel started but it will take quite some time- epoxy needs at least one day curing before I can start any work on it, and I have to go to work sometimes.
Cut out for the dvd tray is done. Dvd panel has about 1 cm distance from the front panel so I have to add some walls to make it look better:However after sanding one of the parts fell off (my bad, I forgot to scratch it before gluing) so I had to attach it one more time:
This time polypropylene part is held against the edge using an acrylic leftover and old telephone cards (when bent they provide quite some force).Front after sanding both longer edges to size:
And after adding shorter walls (from behind):
Both shorter walls are covered with a layer of epoxy, I'll sand them down when it's cured. Of course visible regions of these wall will be of course covered with black paint.I made a 2h test run- 1h of music and 1h of video, both streamed form miniDLNA server.
Running OpenELEC 4.1.6.0 since it supports my remote and doesn't include fan service (so only passive cooling was used)
Temperature
Music playback- most of the time 41 Celsius with top of 42 Celsius.
Video playback- most of the time 50 Celsius with top of 52 Celsius.
Notes:-fan was not used
-case was closed and standing in vertical position (on the side)
-video files used in test have different resolutions (480p to 1080p), compression (divx/xvid, h264, DVD) and bitrates
Wifi
Extension cable works fine, no problems with signal strength or dropping
MCE remote
I have to relocate the antenna, range is ok only when operating the remote on front of the HTPC. In 5.x builds of OpenELEC there is a bug which prevents loading keymap modules, it's being worked on. -
Back panel
05/03/2015 at 19:21 • 0 commentsIt's time to mount the back panel
HDMI mount- I've made a 2x1cm hole for the female-female connector, one end was trimmed down but this was intentional:Mount is made using acrylic scraps and aluminum sheet, this is how it looked before trimming down:
I've epoxied 2 pieces of acrylic to make the back plate more durable near the air ventI could have used thinner ones- air vent area is now much more rigid than the other half ;)
Visible part of the back panel is made out of an old laptop, because it's not long enough I'll use two parts. Getting ready for epoxy:And after gluing all together and trimming down:
I could do it better- connection between black plastics is not the best one, you can see it on the left side of HDMI connector; power adapter is already attached and the hole for mains cable is ready:
And the panel in all it's glory in the case:
All parts in the case are on their places and connected:
Wifi extension cable is made from a thin coaxial cable (removed form a laptop) with crimped RP-SMA connectors. Connectors are made for a thicker one but this one works fine- no problems with signal.As for the MCE remote- I may have to use an older OpenELEC build. I've compiled 5.0.6.0 from sources but still remote is not recognized.
If Kodi/XBMC temperature reading is correct it may be possible not to use the cooling fan after all. During the test run SoC didn't reach 45 Celsius
Power supply casing
04/30/2015 at 18:31 • 0 commentsIt turned out that I can fit the power adapter inside the case without modyfing it. Original adapter's power socket will be used.
Main part of the casing is made of 1mm aluminum sheetThe smaller surface will be attached to the acrylic, holes on the opposite side are necessery to use a screwdriver.
Adapter in casing:Acrylic part will be used to attach the casing to the back panel and main mounting plate. Power adapter fits really tight (it's really hard to get it out)
I'll attach power adapter casing to the main plate when I'm done with the back panelI want to make back panel out of two parts:
-acrylic which will support HDMI, wifi antenna and power adapter casing
-panel made of an old laptop on top of the acrylic- so the everything should look better
For now only air exhaust cutout is ready -
It's alive!
04/26/2015 at 16:44 • 0 commentsUsing Adafruit's TrinketHidCombo library I've managed to make a "proper" usb Power button. It sends System Power Down event (works fine on PC), but in OpenELEC it only launches Shutdown menu and awaits for user selection. So the first solution will be used. Code, schematics and quick'n'dirty readme are on Github (code and readme in PowerBtn2 directory).
Everything is slowly mounted in it's place. And it seems that I should be able to stuff power adapter inside the case :)
Done
-main components are mounted
-fan is working (I've never used my U2 with a fan before)
-PowerCtrl board
-PowerButton
To do:
-powered usb hub
-custom HDMI cable
-extension cable for wifi antenna
-back panel
-maybe an USB port on the front panel
-finish the front panel (sanding paper, bondo, paint etc)Video from today's test run, sorry for quality:
And everything except for power adapter is mounted:
Small box near the PowerCtrl board is Medion X10 MCE USB receiver, antenna-grey wire hanging outside- will be covered with front panel only.
And with DVD mounted:
DVD doesn't touch the USB hub, there's about 2mm of free space left.
Odroid is secured in place
04/25/2015 at 13:52 • 0 commentsIt's time to mount everything in place.
I've cut several straps out of 1mm aluminum, each is approx. 1x2cmBent ones are used to hold the DVD:
4 straps are attached to the Odroid cooler,. Each one is screwed to the cooler and to the main plate using M2 screws:
They are bent unevenly, horizontal part is long enough to allow attaching cooler to the main plate with Odroid in place,also they do not touch Odroid:
Cooler straps have some free space above the main plate, when screws are tightened they will press the cooler against the case which should (hopefully) help in dispatching the heat.Photoresistor mount- made from acrylic leftovers, 2 screws are used for each surface to prevent it from moving:
PowerCtrl board is shrinked in half :) I didn't mount the calibration led, it will be attached temporarily only. On the left side the old board for comparison:
Board is mounted right beside the fan. This will lower cable clutter- power switch (and led) are attached using original short cable, photoresistor won't have to have a long one too:
The fan
04/23/2015 at 12:02 • 0 commentsMain mounting plate is 1mm thinner than motherboard mount points (spacers?), I've added several pads made out of 1mm polypropylene sheet on the bottom.
Fan mounts are made of acrylic scraps (left from previous work), each one has a tapped hole for attaching the fan:All mounts were cut and sanded, exact fit was not necessary:
Fan mounts are glued to the main plate using epoxy glue, main plate was scratched in areas where mounts are touching it before epoxy was applied:
And the fan in place:
On the last picture you can see where I removed plastics from the fan before- just near the lowest mount. Otherwise I'd have to cut out more acrylic which would make the area less durable (initial fan outline is still visible). -
Case, part 2
04/22/2015 at 12:09 • 0 commentsI can't just toss all the electronics inside the case (for reasons which at this moment must be all too obvious ;) ).
On the bottom of the case there are 4 mounts for the mITX motherboard which will hold the acrylic plate in the place. Since I must cut out quite big area to fit Odroid (with cooler) and the fan- DVD will also be used as support.
The beginning- holes for "motherboard" mounts ready, cutouts for front panel mounts ready, cutting lines to make place for DVD marked:
There is still some place left at the back of the case, I will have to fit a back panel there.
I modified the left side of the DVD mount- now it has a smaller footprint and it's easily removable from the case:DVD- right side:
Initial cutout for Odroid and cooling fan:
And main components in place:I removed some plastics from the fan (right side at the bottom, not visible on the picture) as I don't need such wide blowing area, also about 5mm of acrylic was not removed.
Fan will be mounted at an angle - lower near Odroid- it is designed to suck air from both sides. -
Case, part 1
04/21/2015 at 11:24 • 0 commentsThe Itona case had to be modified.
Victim:
It was designed to house a mITX motherboard with 55W PSU. 2 USB ports were present on the front and I hoped that DVD will fit there with minimal effort. Unfortunately the drive was about 1mm thicker than available space so more cutting was required:
Initial fit:
Support for the drive (on the right side) was made using 4mm acrylic I had lying around.
Near the front plate 2 additional pieces of acrylic were added- glued to the centeral one, then I drilled 2 2mm holes to make a taps for the M3 screws:
These were necessary to connect everything to the front plate- additional 2 holes were made and tapped:
Finished mouting:
And the right side DVD mount:
Odroid cooling mod
04/17/2015 at 11:02 • 0 commentsCase I want to use is quite low, stock Odroid cooler won't fit (without modifications).
I found a 38x80mm radiator (from a dead motherboard), half of it was covered with a 1mm thick copper shim:
Cooler after cutting the shim in half, all parts are held together with a thermal glue:
Initial fit:
Original mount points are used:
And finished cooler attached:
SoC is the only part of Odroid touching the cooler, just like in original design.
Thermal surface shuold be big enough to be used without a fan (Odroid-U3 has a smaller one) but since there will be almost no airflow in the case there will be one.
