Source Code
05/01/2015 at 19:19 • 0 comments/* Dan Fruzzetti 2014 * Temperizer code sketch * Version 0.8 */ // ----- GLOBAL ----- // skin sensor pin assignment float sensorPin = 0; // Accommodation of last few values for smoothing algorithm float SV1 = 0; float SV2 = 0; float SV3 = 0; float SV4 = 0; float SV5 = 0; float SV6 = 0; float SV7 = 0; float SV8 = 0; // buzzer pin assignment int buzz = 12; float C = 3; int debug = 0; // SVriable to store the SVlue coming from the sensor float voltage; // Time SVriables unsigned long time; // Reassignable per hardware / sensor needs float secForGSR; float curMillisForGSR; float preMillisForGSR; // ----- END GLOBAL ----- // initial conditions and one-time setup void setup() { // Switch commented lines to toggle debugging output (1 = yes; 0 = no) debug = 0; // debug = 1; // Prepare serial port output Serial.begin(9600); // Frequency of sensor data acquisition (in seconds) secForGSR = 0.125; curMillisForGSR = 0; preMillisForGSR = -1; } void loop() { // Uncomment for buzzer and light test at power-up /* digitalWrite(buzz, HIGH); * digitalWrite(3, HIGH); * delay(1000); * digitalWrite(3, LOW); * delay(1000); */ // define extrema float maximum = 0; float minimum = 1290; /* Prior code versions used these * time = millis(); * digitalWrite(12, HIGH); * SV1 = analogRead(A0); * curMillisForGSR = time / (secForGSR * 1000); * if(curMillisForGSR != preMillisForGSR) { * Read GSR sensor and send over Serial port */ // acquire SVlue # 1 SV1 = analogRead(sensorPin); // debugging block if (debug == 1) { Serial.print("SV1 == "); Serial.println(SV1); } delay(SV2); // acquire SVlue # 2 SV2 = analogRead(sensorPin); // debugging block if (debug == 1) { Serial.print("SV2 == "); Serial.print(" TEST SV2 - SV1 == "); Serial.print(SV2 - SV1); Serial.print(" And SV2 == "); Serial.println(SV2); } if((SV2 - SV1) >= 1) { digitalWrite(3, HIGH); digitalWrite(12, HIGH); } delay(SV2); digitalWrite(3, LOW); delay(SV3); digitalWrite(12, LOW); // acquire SVlue # 3 SV3 = analogRead(sensorPin); // debugging block if (debug == 1) { Serial.print("SV3 == "); Serial.println(SV3); } if((SV3 - SV2) >= 1) { digitalWrite(3, HIGH); digitalWrite(12, HIGH); } delay(SV3); digitalWrite(3, LOW); delay(SV4); digitalWrite(12, LOW); // acquire SVlue # 4 SV4 = analogRead(sensorPin); // debugging block if (debug == 1) { Serial.print("SV4 == "); Serial.println(SV4); } if((SV4 - SV3) >= 1) { digitalWrite(3, HIGH); digitalWrite(12, HIGH); } delay(SV4); digitalWrite(3, LOW); delay(SV5); digitalWrite(12, LOW); // acquire SVlue # 5 SV5 = analogRead(sensorPin); // debugging block if (debug == 1) { Serial.print("SV5 == "); Serial.println(SV5); } if((SV5 - SV4) >= 1) { digitalWrite(3, HIGH); digitalWrite(12, HIGH); } delay(SV4); digitalWrite(3, LOW); delay(SV5); digitalWrite(12, LOW); // acquire SVlue # 6 SV6 = analogRead(sensorPin); // debugging block if (debug == 1) { Serial.print("SV6 == "); Serial.println(SV6); } if(((SV6 - SV5)) >= 1) { digitalWrite(3, HIGH); digitalWrite(12, HIGH); } delay(SV5); digitalWrite(3, LOW); delay(SV6); digitalWrite(12, LOW); // acquire SVlue # 7 SV7 = analogRead(sensorPin); // debugging block if (debug == 1) { Serial.print("SV7 == "); Serial.println(SV7); } if(((SV7 - SV6)) >= 1) { digitalWrite(3, HIGH); digitalWrite(12, HIGH); } delay(SV6); digitalWrite(3, LOW); digitalWrite(12, LOW); delay(SV7); // acquire SVlue # 8 SV8 = analogRead(sensorPin); // debugging block if (debug == 1) { Serial.print("SV8 == "); Serial.println(SV8); } if(((SV8 - SV7)) >= 1) { digitalWrite(3, HIGH); digitalWrite(12, HIGH); } delay(SV6); digitalWrite(3, LOW); delay(SV7); digitalWrite(12, LOW); // clean-up digitalWrite(3, LOW); // preMillisForGSR = curMillisForGSR; /*Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V): print out the SVlue you read:*/ /*if ((SV2-SV1) > 0){ digitalWrite(buzz, HIGH); digitalWrite(3, HIGH); delay(1000); } // SVlue comparators if(SV8 > maximum){ maximum = SV8; } if(SV1 < minimum){ minimum = SV1; } if(SV2 < minimum){ minimum = SV2; } if(SV3 < minimum){ minimum = SV3; } if(SV4 < minimum){ minimum = SV4; } if(SV5 < minimum){ minimum = SV5; } if(SV6 < minimum){ minimum = SV6; } if(SV7 < minimum){ minimum = SV7; } if(SV8 < minimum){ minimum = SV8; } SV7 = SV8; float SVD78 = (SV8-SV7)/secForGSR; if(SV7 > maximum){ maximum = SV7; } SV6 = SV7; float SVD67 = (SV7-SV6)/secForGSR; if(SV6 > maximum){ maximum = SV6; } SV2 = SV3; float SVD23 = (SV3-SV2)/secForGSR; if(SV2 > maximum){ maximum = SV2; } SV3 = SV4; float SVD34 = (SV4-SV3)/secForGSR; if(SV3 > maximum){ maximum = SV3; } SV4 = SV5; float SVD45 = (SV5-SV4)/secForGSR; if(SV4 > maximum){ maximum = SV4; } SV5 = SV6; float SVD56 = (SV6-SV5)/secForGSR; if(SV5 > maximum){ maximum = SV5; } SV1 = SV2; float SVD12 = (SV2-SV1)/secForGSR; if(SV1 > maximum){ maximum = SV1; } // clean-up digitalWrite(3, LOW); delay(1000); // recalibration - a weighted average in v0.8 code float voltage = ((SV1 + SV2 + SV3 + SV4 + SV5 + SV6 + SV7 + SV8 + (3*maximum) + (3*minimum)) / 14); // debugging block if (debug == 1) { Serial.println(voltage); } }Version 0.8 source code posted here. This uses a 'dumb' weighted average process which is not cumulative between samplings. We plan to use a cumulative weighted average process which will aid in squelching false "trend positives" when worn all day. We are, however, happy with the smoothing this simple algorithm offers, which decreases detection of "instantaneous false positives".
Initial Build Info and Plan for 2015
04/23/2015 at 22:20 • 0 commentsOctober: conceived of the idea
October: built the first prototype
December: miniaturized the prototype
January through March: absolutely nothing
April: revisited the math and improved the stress-sensing algorithm (which code will eventually be made available publicly as soon as I master the squelch algorithm; anyone who wants to help can have it now).
By August 2015: to complete the three main tasks required.
By November 2015: to complete playtesting with a statistically significant number of individuals from all subgroups (that's a large number).
Dan Fruzzetti
