Here's some code...
08/16/2015 at 00:52 • 0 commentsDefinitely not elegant or optimal, but here's what is presently running this thing:
#include <SevenSeg.h>
#include <Wire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_LSM303_U.h>
SevenSeg disp(10,12,7,8,9,11,A2);
const int numOfDigits=4;
int digitPins[numOfDigits]={5,4,2,6};
volatile int indexMode = 0;
char* nounAZ[] = {"lamp", "desk", " car", " dog", " cat", "door", "bike", "shoe", "tree", "shed", "fork", " tea", "hill", " job", "head", "food", " cup", "cafe", " dad", " mom"};
char* verbAZ[] = {" is", " was", " are", " ate", "goes", "runs", "eats", "wins", "sees", "gets", "puts", "cuts", " had"};
char* adjAZ[] = {" big", "blue", "tiny", " red", " bad", "good", "easy", " wee", "huge", " mad", " sad", "glad", " rad", "near", " far", " low", "high", "wide", "thin", " hot", "cold", "cool", "warm"};
int poem1[] = {8, 1, 2, 3, 1, 1, 2, 3, 1};
int poemLength = poem1[0] +1;
Adafruit_LSM303_Mag_Unified mag = Adafruit_LSM303_Mag_Unified(12345);
void setup() {
disp.setDigitPins(numOfDigits,digitPins);
disp.setDPPin(13);
pinMode(3, INPUT);
attachInterrupt(1, changeMode, FALLING);
if(!mag.begin())
// the loop function runs over and over again forever
void loop() {
switch (indexMode) {
case 0:
for (int pmode=1; pmode<150; pmode++) {
disp.write("poem");
delay(10);
displayPoem();
break;
case 1:
for (int tmode=1; tmode<150; tmode++) {
disp.write("time");
delay(10);
printTime();
break;
case 2:
for (int dmode=1; dmode<150; dmode++) {
disp.write("dirn");
delay(10);
printDirn();
break;
void displayPoem(){
int i = 1;
int poemLength = poem1[0] + 1;
while (i < poemLength) {
int poemIndex = poem1[i];
if (poemIndex == 1)
printNoun();
else if (poemIndex == 2)
printVerb();
else if (poemIndex == 3)
printAdj();
else
Serial.println("oops");
i++;
for (int j=0; j<=129; j++) {
disp.write("fini");
delay(5);
void printNoun(){
randomSeed(analogRead(1));
int numTD;
numTD = random(19);
delay(150);
for (int b=0; b <=100; b++){
disp.write(nounAZ[numTD]);
delay(5);
delay(500);
void printVerb(){
int numTD;
numTD = random(12);
delay(150);
disp.write(verbAZ[numTD]);
delay(5);
delay(500);
void printAdj(){
int numTD;
numTD = random(22);
delay(150);
disp.write(adjAZ[numTD]);
delay(5);
delay(500);
void printTime(){
tmElements_t tm;
if (RTC.read(tm)) {
//delay(1000);
int hours = tm.Hour;
int minutes = tm.Minute;
for (int j=0; j<=333; j++) {
disp.writeClock(hours,minutes);
delay(5);
void printDirn(){
//disp.write("dirn");
/* Get a new sensor event */
sensors_event_t event;
mag.getEvent(&event);
float Pi = 3.14159;
// Calculate the angle of the vector y,x
float heading = (atan2(event.magnetic.y,event.magnetic.x) * 180) / Pi;
// Normalize to 0-360
if (heading < 0)
heading = 360 + heading;
for (int c=0; c <333; c++) {
disp.write(heading);
delay(15);
void changeMode() {
++indexMode %= 3;
PCB beginnings
07/29/2015 at 20:28 • 0 commentsJust rediscovered Upverter, have started learning the ropes and creating my schematic. The goal is to layout a pcb for the "permanent" version of this thing. I have some protoboards that I could use, but as a large motivation behind this endeavour is to learn new stuff I would prefer to get some experience with producing a pcb layout.
Some (more) progress
06/26/2015 at 19:32 • 0 commentsHere's a schematic of the current setup. Had to do a little connection shuffling to free up digital pin 2 for the external interrupt, using the tact switch to change modes (poem, clock, compass). Next step is to gather the useful parts of my various test sketches into a functioning unit and tweak the poetry portion.
Some progress...
06/04/2015 at 16:27 • 0 commentsThe two modules arrived and I assembled the DS1307 RTC kit. The basic code for generating the "poems" is working (still on the Pro Mini). I attempted to compile it for the Teensy-LC but got an error related to the library I'm using for the seven segment display and a warning related to using an array of strings. I'm debating whether to figure these issues out now before proceeding with the Teensy-LC or if I should continue with the Pro Mini and then adapt for the LC later. Any ideas of alternative ways to handle the seven segment display on the Teensy?
Parts acquisition
05/14/2015 at 16:23 • 0 commentsJust ordered the RTC and magnetometer modules. Decided on the LSM303 triple-axis accelerometer and magnetometer from Adafruit as the feature/price factor seemed like the best value. Continuing to sketch ideas about how to use the seven segment display in various ways and reconfigured the circuit-thus-far on the breadboard to make room for the two modules.
