SD works!
07/05/2015 at 03:20 • 1 commentBuilt a new one with SD card and it works!
ESP is reading the SD card nicely.
New board seems to be bug free. Party time.
Now the question is, should I attach the Teensy Side to the SD card and thus the ESP8266 via SPI as well. This may mean I will have to change to a 6 layer board.
Next task. Indigogo project, lets see what the maker community make of this, see If I can sell 1000 units. Current price looks around $39 (NZD) so $26USD at current exchange rate.
New PCB arrived
07/02/2015 at 10:34 • 0 commentsNew and improved (aka bug fixed) PCB's have arrive. That was really fast turn around. Thanks pcbzone.
The PCB Trace antenna now works like a charm. Now need to test the SD card attached to the ESP8266 and see if it can serve up some webpages.
Time to rule the world :)
Initial Log Entry
06/29/2015 at 01:44 • 0 commentsMoved from Description was in the wrong place (Doh!)
Currently tuning the Wifi Antenna. My First PCB Trace Antenna was incorrect as I mis calculated the Feed Trace Width and Antenna length. But the Ceramic antenna saved the day.
Time to search for someone with a Network Analyser or Spectrum Analyser that won't charge the Earth to use it, or find some Low Cost 2.4Ghz add on for my Oscilloscope.
29Jun Update
06/29/2015 at 01:43 • 0 commentsI've fixed a few bugs and rerouted some of the lines from the Ground plane to the data layer (Yes I know, bad form putting traces in the ground plane, but I just can't seem to find a route without using this plane).
I've added a Micro SD card socket as there's room for one, and hooked it up to the ESP8266, ideal for serving Webpages and images.
Ordered a new board and stencil from the Manufacturer. Let's hope everything is now correct.
