SunSafe - A solar powered safety light
A waterproof solar powered LED safety light for your backpack, kids and pets
A solar powered LED light to keep you, your kids or pets, visible and safe at night. It has a really lame name at the moment but I can't think of anything else, suggestions welcome!
A friend of mine recently took on a massive 52 mile walk over 24 hours and since part of it was in the dark he wore a head torch. I thought about how people wear reflective strips so that cars can see them but they were not wearing anything else to keep them visible.
I thought it would be cool to build a cheap and long-lasting solar powered light to keep the wearer visible at night.
The project took inspiration from cheap garden solar lights but toned down the need for bight illumination and focussed instead on low level light that can last a very long time on a small solar charge.
The project is currently working in the 0.6ma range from 2 rechargeable AA batteries, the lower the voltage the lower the current draw. This should give an extremely long life to the batteries on a minimal charge from the sun.
Project overview (2 minute video):
My first prototype:
Initial experimentation:
  • 2 × Solar Cell 4v 50ma
  • 2 × AA Rechargeable Battery 800mah
  • 2 × General purpose Schottky diode
  • 1 × Waterproof cell/mobile phone packet
  • 12 × White strawhat LEDs
View all 9 components
  • 3D Print!!!!!!
    David Watts08/16/2015 at 20:09 0 comments
    It is finally here!!!! Now I just need to fit all the parts, time to get the veroboard out.
  • 3D Printing the case
    David Watts08/06/2015 at 22:37 1 comment
    Ok, so the title is a little misleading. I have just designed the case with a bit of help from the community and its is being printed by another lovely person from the community.
    Model rendered, you can see the cutout for the solar panel and LEDs
    Here is the sliced model ready for printing
    Ridiculously excited to have a 3D printed object in my hands.
  • It is all coming together
    David Watts07/26/2015 at 18:31 0 comments
    I am quite satisfied with the progress so far, just one more part to decide on and they I can concentrate on creating an equaly simple method of packaging this thing. Of course, it needs to be lightweight and waterproof. More testing :-( required I am sure.
  • More testing, I know it is a bit boring
    David Watts07/20/2015 at 13:01 0 comments
    More testing complete with the solar panel and batteries in circuit.
    This is a little graph (actually quite big) of the 4v solar panel in circuit and charging the batteries. I hooked up my multimeter to a laptop to record mAs and rigged up and Uno + Ethernet shield to record the voltage. I only ran this for just over an hour because it was a day with patchy cloud and I was worried about rain (not waterproof yet). Still, the results are encouraging.
    The voltage output from the solar panel is pretty steady and around the level I need, certainly enough to charge the batteries. The current level fluctuates a lot, this is down to cloud cover and angle toward the sun.
    If I can source a diode with a lower voltage drop diode, like a good Shotkky diode or perhaps use a reversed P Channel Mosfet bodge, then the voltage from the panel to the batteries will be more than sufficient.
    In terms of current the average making it into the batteries over the time period was 4ma, sounds a bit crap right? Well in just over an hour on a cloudy day the battery voltage increase by 0.05v and on a sunny day it would be much more efficient. You can see from the graph where the sun appear from behind the clouds which yielded a whopping 21ma at peak. If we could chuck that into the batteries we could run the lights for 40 hours. If you recall the voltage drop on the batteries running the LEDs for 2 hours was 0.005v.
    Should I worry about over charging the batteries? Not really. NiMh batteries tend to lose some of their charge each day and a trickle charge of 0.1c (100th of the battery's capacity) is fine according the the battery manufacturer.
    I forgot to take a picture outside... sorry.
    With a bit of careful part choosing for the diode or equivalent and some circuity to switch on and off the LEDs (Probably a transistor from solar panel) this setup should meet the requirements.
    Woahh! Steady on there, this panel is producing a massive 0.06 watts at peak!!!!!!
  • Test Results
    David Watts07/13/2015 at 20:27 0 comments
    **These results were confirmed by periodic measurements with my digital multimeter**
    So after leaving my test for 2 days and forgetting to insert an SD Card for 1, I finally have some results.
    I wanted to test our the voltage drop, which helps me understand the discharge curve of the batteries. These are often available for popular batteries but never in the sub-milliamp range. My results show a clear trend and some evidence of leveling out, which is what I would expect as a NiMH battery tends to stick at 1.2v for longer. This could mean the batteries would last a lot longer that I assume even though 2.4v does mean pretty low brightness.
    I would like to er of the side of caution with any claims about runtime.
    I also calculated a current graph using the known 460 ohm resistance and the voltage.
    Kinda the same right? Voltage and current are directly related in this scenario so this is what I would expect to see.
    Next up, the solar panels.
  • Doing some testing
    David Watts07/12/2015 at 11:21 0 comments
    I have the basics down, solar panel charges the batteries, batteries power the LEDs switched by a PNP transistor. But... I really want to be able to test how long it will last and how much power I need to gather from the solar cell/s to provided adequate illumination time.
    Commence testing:
    I have the batteries powering the LEDs and the UNO + Ethernet shield combo is sucking in voltage data and saving it to a CSV file on the micro SD Card. It has been running for +18 hours so hopefully that should give me enough data to look at the voltage over time, which will help me look at a discharge curve but also the current used.
    I will update once the batteries drop to 2.5v which is where I think the LEDs will be too dim to be useful. I reckon they have another day left.
    The next test will be of battery charging but that will have to wait until it is not raining, I know it will be waterproof but I am not.
  • The road so far...
    David Watts06/26/2015 at 22:24 0 comments
View all 7 project logs
Rich text editor
hackaday wrote 07/20/2015 at 13:57 point
Check out some of the Dave Johnson http://www.discovercircuits.com circuits for flashing LEDs. I built one of his 3v flashers and powered it by a small 6v solar panel and a 1 F supercap. With a few hours of direct sunlight it would flash all night.
David Watts wrote 07/20/2015 at 14:28 point
Very cool, thank you.
davedarko wrote 07/20/2015 at 13:32 point
To increase the visibility, do you think it makes sense to try out a technic that is used in backlights for displays - LEDs shining onto the edge of an acrylic sheet that is sanded/diffused?
David Watts wrote 07/20/2015 at 13:56 point
Thanks mate, I will give it a go when I get to making the housing. I will try out a few options.
Jack Laidlaw wrote 07/13/2015 at 20:49 point
Great idea!
peter.b.grain wrote 06/30/2015 at 00:04 point
Well done David
Eric Wiiliam wrote 06/27/2015 at 01:43 point
Simple and effective.  Love it.
