Einstein-Rosen Bridge (WiFi)
An encrypted WiFi bridge from my house to my mother-in-laws house across the back court so she can watch Netflix
My mother-in-law absolutely loves her Shows and Movies, so rather than go down the shady route of not paying for content, we have signed up for Netflix. I have plenty of bandwidth and instead of trying to go through the pain of getting a broadband connection in an area where there are no more ADSL2+ connections available (and no NBN as yet), I decided just to share my bandwidth.
I tried several tests accessing my home WiFi from my mother-in-law's house being she only lives about 55 meters away across the back court but on the days that I could even sniff my SSID from her back door, I couldn't do anything with the link. Inside her house there was no SSID at all.
I decided to build a pair of dedicated boxes coupled with some nice high gain Yagi antennas attached to our TV antenna poles which have a nice line of sight to each other and somehow manages to avoid the trees in the neighbours yards. One box is called Einstein the other is Rosen, since we all love bridges across
I have build two Raspberry Pi based boxes that connect to each other via WiFi on Channel 1 (2.4GHz) since no other WiFI AP in the area is using that channel, so I get a nice high-speed uncongested link.
The WiFI dongle on my end is in AP mode, serving up the SSID for the bridge. The other box connects to this and connects to an OpenVPN server running on the Pi 2. The WiFi is firewalled on both ends so that the only traffic allowed on the link is the OpenVPN traffic and ICMP packets for testing the endpoints are responding.
I included a 1TB USB hard disk in each box with the root Raspbian filesystem on the USB drive in order to save the SD Cards from wear and tear. It also gives plenty of room for implementing at a later stage transparent HTTP(S) proxying & caching. I am looking at implementing a local cache for other frequently accessed media in order to reduce the load across the bridge also.
I picked up a couple of 5V 15W switchmode power supplies from ebay to handle powering the Pi and WiFi dongle which being a cheap unit didn't exactly have the smoothest output. I whipped up a couple of filter boards with an inductor and a handful of capacitors of various sizes on some Veroboard to get the ripple under control.
I also created a breakout for the GPIO header on the Pi 2 so I could add a Dallas 1-Wire temperature sensor (CrystalFontz have some really nice temperature sensors based on the DS18B20 digital sensor for the CFA-6xx Series) for monitoring the environment inside the enclosure.
I sourced some weatherproof ABS boxes from an electrician friend who I do some work for on the side from time to time which I have mounted all the equipment in, It's laid out nicely if not a bit cramped. The boxes will be mounted on the TV antenna mast along with the 2.4GHz Yagi antenna to keep the cable length as short as possible.
  • 1 × Raspberry Pi 2 Model B My end CPU board
  • 1 × Raspberry Pi Model B+ Mother-in-law end CPU board
  • 2 × 110-240v to 5v 15w Switchmode PSU $7 from ebay (ea)
  • 2 × 2.4GHz Yagi antenna $20 from ebay (ea)
  • 2 × TP-Link 150Mbps 2.4GHz WiFi USB Dongle With external SMA connector for antennas
View all 19 components
  • Challenge Accepted
    robheffo09/18/2015 at 03:25 0 comments
    Due to a pending size increase for my family, it seems we will be moving to a new house. And with it comes some additional challenges for the WiFi bridge.
    We aren't moving all that far, only a couple of minute drive into a much larger (and maker friendly) house. But it does increase the distance of the bridge quite significantly. Not being one to quit when things suddenly get interesting, I have decided to add a repeater node on a nearby hill since I will no longer have line-of-sight to my mother-in-laws house.
    There are some additional challenges this time that I can forsee:
    • The additional 4.75(ish) km of round-trip range.
    • Powering a repeater 24/7 with no power supply (Solar FTW!)
    • Protection of the repeater from vandals
    • Antenna design (good quality directional antennas)
    • Regulations!
    More updates pending as I tackle the issues!
  • Barometric Pressure Sensor
    robheffo09/07/2015 at 02:55 0 comments
    Having remembered I had a BMP085 pressure sensor breakout in my shed from an old project, I set about adding it to the Einstein box's growing list of sensors.
    Since the enclosure is IP68 rated it's pointless putting the sensor in the enclosure so I needed to route it outside but also need to keep it out of direct sunlight and out of the water.
    I done a trip to Bunnings and picked up a cheap Junction Box and some silicone sealant to use to glue the box to the side of the enclosure. Then I went to Jaycar for some wire, a pin header plug and an IP68 cable gland.
    I assembled the cable connector and tinned the wiring on the ground before climbing on the roof of the shed to install the sensor. I took my Soldering Station onto the roof with me as thankfully I was able to disconnect the power from the Raspberry Pi 2, then unplugged the power-pack for the Hard drive and used the mains power socket to power the Soldering Station.
    I drilled the hole for the cable gland in both the existing enclosure and the junction box but the thread on the cable gland was nowhere near long enough to use the gland to attach the two together. I prioritised the enclosure and used the rubber gasket to ensure it was water tight, then drilled the hole in the junction box oversize so it would fit over the top of the cable gland. I used the silicone sealant to glue the junction box to the side of the enclosure.
    I soldered the GND, SDA and SCL lines to the second set of terminals on the TinyRTC module but had to run a wire upto the GPS module to tap the 3.3v VCC terminal there since the TinyRTC is a 5v board. Once that was complete, I plugged the BMP085 board into it's header and screwed the cover on the junction box, plugged the HDD back into power, reconnected the Raspberry Pi 2's power and put the cover back on the enclosure.
    Once back inside I SSH'd into Einstein and ran a quick "sudo i2cdetect -y 1" and the sensor was present on the i2c bus which was a good sign given the sensor had been sitting in my shed for a year or so in a breadboard doing nothing but gather dust.
    I installed the Adafruit Python library for the BMP085, ran the install script then fired up the simpletest.py example file and was greeted with some good looking data.
    Now all that is left to do is to start working on a web framework to extract, log and display the ever increasing list of data being grabbed by Einstein. I do have some plans for future sensors but I need to work on some hardware before I can install them!
  • Einstein Science Upgrade
    robheffo09/01/2015 at 03:50 0 comments
    Given the additional RAM and CPU capacity of the Raspberry Pi 2 in the Einstein box I have decided to do some "Upgrades" on the hardware in the box to try an do some science.
    As part one of this is to install a Real Time Clock so the Pi 2 has an actual Hardware RTC, and a GPS for accurate location measurements and time keeping, etc. A quick trip to Ebay and I had a cheap TinyRTC module and a uBlox 6M GPS ordered which turned out to be fully functional and no issues which is good given you can occasionally get some bad modules from the cheap Chinese sellers.
    The TinyRTC board was modified to remove D1, R2, R5 and to remove and wire bridge R6 so that I could replace the rechargable LIR2032 battery with a much easier to source CR2032 battery. The CR2032 batteries in this application last 10 years so it's no issue not having a rechargable battery.
    I wired both the uBlox and the TinyRTC up to a harness which connects to the GPIO header on the Pi 2. I then grabbed my spare Pi 2 and done some testing on the bench. I did find I had the GND, TX and RX lines messed around on the uBlox module but a quick shuffle of the pins in the plug on the harness and that issue was resolved without breaking the module.
    I configured Raspbian to use the TinyRTC as the HW clock and setup GPSD and verified everything was working fine and now all I need to do is get on my shed roof to install the harness into Einstein.
  • Bridge Installed
    robheffo07/19/2015 at 23:41 0 comments
    Having completed the software installation (Part 2 of my configuration log is pending) I spent this afternoon installing the boxes in their final locations.
    My box was installed on the roof of my garage as the existing TV antenna mast was too far away from my garage where my switch gear is located.
    The antenna was aimed by eye at the TV antenna mast at my mother-in-law's house, the spread on the signal will easily take care of any misalignment. The only issue I faced was my next door neighbour's shed and a bottle brush tree in my mother-in-law's neighbour's yard
    After installing the second box and aiming it back at my garage roof, I connected my phone to my mother-in-law's access point inside the house, opened a terminal and was able to ping across the bridge with no issues.
    Trying to ping the internet was failing but a quick traceroute showed the packets were stopping at my cisco router. A quick tweak to the access lists allowing my mother-in-law's subnet and the issue was resolved.
    The link speed isn't the greatest but given the obstacles in the way it's probably not unexpected. The Link Quality varies and the Bit Rate tends to shift back and forwards between 18Mb/s and 24Mb/s. I would have liked a higher speed, but it is still enough to saturate my internet link.
    I do need to do some tuning with OpenVPN to try and work on the speed of the encryption. I was only getting about 3.5MB/s to 4MB/s transfer speeds and it was maxing out the Pi 1's CPU. I will be doing some monitoring of the CPU temperature to see if a mild overclock is possible, it was a frosty morning this morning and the Pi 1 was running about 30°C where my Pi 2 was only 18.5°C (for reference, the standing water pools outside were frozen)
    Finally I was able to install a Chromecast on my mother-in-law's TV and set her phone up with the Chromecast and Netflix apps, she was able to watch some legal TV goodness with no stuttering or quality issues so over-all I would call the exercise a success.
  • Raspbian Configuration - Part 1 (Base System)
    robheffo07/13/2015 at 13:02 0 comments
    Having lost my original SD card image when the card failed, I needed to rebuild my Raspbian configuration. This is the outline of the process I used to rebuild the image and configure Raspbian and OpenVPN to act as the wireless bridge between the two houses. I started the process with a fresh NOOBS based install of Raspbian.
    Step 1: Update Base Install
    Firstly, I need to update the packages to the latest versions. I open a connection to my Pi 2 with Putty from my Windows box.
    I execute the commands:
    sudo apt-get update
    sudo apt-get upgrade
    The first command updates the package metadata so that apt knows what is available. The second command scans the system, prompts for permission then downloads and installs the updated packages.
    Step 2: Configure eth0 and wlan0 network interfaces
    Next I need to configure the IP addresses used by the Pi 2. DHCP assigned addresses aren't suitable for a device intending to act as a network gateway, so I need to configure static IP addresses for both eth0 (Wired LAN) and wlan0 (WiFI).
    I execute the command:
    sudo nano /etc/network/interfaces
    Then I delete the existing contents and use the following config (My actual IP's have been masked)
    auto lo
    iface lo inet loopback
    auto eth0
    allow-hotplug eth0
    iface eth0 inet static
            address xxx.xxx.xxx.xxx
            netmask xxx.xxx.xxx.xxx
            gateway xxx.xxx.xxx.xxx
            dns-nameservers xxx.xxx.xxx.xxx
    auto wlan0
    allow-hotplug wlan0
    iface wlan0 inet static
    Next, I need to disable the DHCP Client Daemon (dhcpcd) which I found assigns the network interfaces a DHCP address even though I have set a static IP above.
    To do this I use the command:
    sudo update-rc.d dhcpcd disable
    Step 3: Set Hostname & GPU Memory Split
    Now I just need to configure the Hostname and the amount of RAM assigned to the GPU in the Broadcom SoC before rebooting. Since the GPU will not be needed I will be assigning it 16MB of RAM which is the smallest amount possible. To perform this configuration I will use the 'raspi-config' utility.
    I use the command:
    sudo raspi-config
    First I set the Hostname. I access the 'Advanced Options' menu, choose 'Hostname' and enter 'Eienstein'.
    Then I set the GPU Memory. Again I access the 'Advanced Options' menu, then I choose 'Memory Split' and enter '16'
    I then choose the 'Finish' option to complete the process. I am prompted to reboot and choose 'Yes' which reboots the Pi 2.
    Step 4: Enable IP Forwarding
    After waiting a couple of minutes and reconnecting to the Pi on it's new IP address, I am ready to enable IP Forwarding which allows the linux kernel to route packets between interfaces by using the routing table.
    sudo nano /etc/sysctl.conf
    I locate the line containing '#net.ipv4.ip_forward=1' and remove the hash to uncomment the line. This script is used by linux during the boot process to configure certain system parameters, in this case forwarding of IPv4 packets.Next I execute the command:
    sudo sysctl -p /etc/sysctl.conf
    This causes the system to reload the configuration file and apply the changed settings.
    Step 5: Configure Wireless Access Point for wlan0 interface
    Now I need to configure the wlan0 (WiFi) interface to act as a Wireless Access Point so the other box can connect to the wireless network without requiring a dedicated access point. I need to install the 'hostapd' daemon in order to act as the access point.
    I run the commands:
    sudo apt-get install hostapd
    sudo nano /etc/hostapd/hostapd.conf
    The first line uses apt to download and install the daemon, the second line created a new configuration file for the daemon. I use the following config (again masking identifying details)
    interface=wlan0
    driver=nl80211
    ssid=xxxxxxxx
    hw_mode=g
    #wme_enabled=1
    #ieee80211n=1
    #ht_capab=[HT40+][SHORT-GI-40][DSSS_CCK-40]
    channel=11
    macaddr_acl=0
    auth_algs=1
    ignore_broadcast_ssid=0
    wpa=2
    wpa_passphrase=xxxxxxxx
    wpa_key_mgmt=WPA-PSK
    wpa_pairwise=TKIP
    rsn_pairwise=CCMP
    This config sets up an 802.11g Wireless LAN on channel 11 which in my...
  • Block Diagrams
    robheffo07/09/2015 at 06:36 0 comments
    I have added to the Gallery simple block diagrams of the enclosures on each end of the link.
    The Eienstein enclosure is on my end and is responsible for acting as the WiFi Access Point and serving up the OpenVPN connection across the WiFi link to Rosen.
    Rosen is the far end, acting as the Client, connecting to the Eienstein AP and the OpenVPN client. It is also responsible for assigning IP addresses, Gateways and DNS via DHCP to the remote lan.
    Once I have the link working, I will add web caching to Rosen to try and reduce load across the WiFi link, and also (if possible) locally caching any media from a NFS or SAMBA share on my local LAN.
  • Two Pi 2's and from scratch software
    robheffo07/08/2015 at 13:56 0 comments
    So, I should have taken the warm SD card as a sign, I got home and connected up my new Pi 2 only to be presented with the same symptoms as the previous board.
    I put the SD card into a PC reader and got some strange results from Windows trying to read the card. I grab a spare Micro SD and throw a fresh copy of Noobs on it and sure enough the Pi boots. I swapped the card into the old Pi 2 and it leaps into life also. Score!!
    So now I have two working Pi 2's, a cactus Sandisk 16Gb MicroSD and no working, tested OS left. On the bright side, I can now do project logs on the configuration of Raspian to act as the encrypted bridge.
  • Pi 2 Arrived (Eventually) & Electrician Organised
    robheffo07/08/2015 at 06:04 0 comments
    So, finally after almost a whole day of waiting and two trips to the Post Office, I have my new Pi 2. I got an email from Australia Post saying my package had been delivered. No one around the office had seen it. I dashed home during my lunch break to see if it had been delivered there (alas, it had not) and to meet up with my Electrician friend who is installing power & ethernet under the eaves to show him the Job.
    I also have to have my mother-in-law's fuse box rewired with all new breakers and safety switches because of the age of the house but it's only going to cost me some time working on his office PC's and fixing his Arcade Machines.
    I checked in with the Post Office near work where the office mail comes too and there was no sign of the package at all. I had a meeting to attend to so couldn't hang around. Not long before the Post Office closed, I done a quick trip back and they had managed to locate the parcel, it was put into my office's PO Box for delivery tomorrow.
  • Replacement Pi 2 Ordered
    robheffo07/07/2015 at 03:09 0 comments
    So, AU$69 later and my replacement Pi 2 is on the way from Little Bird Electronics. Express post to my office so hopefully I will have it tomorrow.
    I also have organised my electrician friend to come around to install outdoor Mains Power and Ethernet points under the eves near the TV antenna at my mother-in-law's house.
  • Assembly of Pi 2 WiFi Box
    robheffo07/06/2015 at 11:12 0 comments
    The assembly of my Raspberry Pi 2 based WiFi box was very straight forward. The power USB cable on the Pi 2 was a bit snug against the veroboard for the GPIO header breakout but it went in no problem after trimming a notch out of the board.
    Once it all went together and I plugged it in to power, the board lights lit up and the HDD spun up but there was a solid ACT light on the Pi 2. I extracted the Pi 2 and powered it up connected to my PC and still there was nothing, no HDMI signal and no ACT light.
    The MicroSD card also started to get a little warm to the touch, not a good sign. I had the Pi 2 configured and working on the bench prior to assembly, looks like I have to order another one pronto from Little Bird Electronics!
    Note to the Raspberry Pi Foundation: Hey Guys! How about a thin conformal coating to help protect the base PCB from accidental spikage!
View all 10 project logs
greenaum wrote 11/18/2015 at 13:35 point
http://www.hackaday.com/2005/06/13/ronja-optical-data-link/
Ah! Look where I found it. Probably!
The
design originates from 2001 so it's well-tested, thought to be between
1,000 - 2,000 setups using it in the world. So it's not gonna be too
hairy. Especially with the short distance it has to work in your case.
greenaum wrote 11/18/2015 at 13:23 point
There's a project a Czech guy did called RONJA. It's made it into Wikipedia, apparently, if that's a mark of success! Uses strong LEDs, and is pretty impressive. Claims 1.4KM range at 10Mbps, which isn't fast by today's standards but should be good enough for anything your mother-in-law wants.
There's options for either red or IR LEDs. Has a standard Ethernet connection, I think. Definitely worth checking out.
http://ronja.twibright.com/ is the site address. It was still a hack project last time I looked, dunno how well he's developed it.
greenaum wrote 11/18/2015 at 13:19 point
It's a shame it's not an Einstein-Rosen-Podolsky bridge. Because then you could say you're using an ERP PHY!
J.D. wrote 07/06/2015 at 21:10 point
check out VLC visible light communication...there are some open source projects...the alternative is laser based comm links (125m@100MB/s+ to 1GB/s)
robheffo wrote 07/06/2015 at 22:37 point
I started looking into Light/Laser based links when I was putting the plan together, while I was really keen to pursue the idea I needed something I could put together quickly and didn't involve shining lasers across the house for testing purposes. My fiancée's fuse is running out enough as it is with this project (I think the only reason she tolerates it as it is is because it's helping her mother out!)
J.D. wrote 07/08/2015 at 16:39 point
well I read that normal white leds can be modulated at up to 20mhz...so no lasers required...you just need a strong 1-3 watt led with a good lense for directional accuracy...of course i understand your circumstances in not pursuing the idea...its only a tip for futur experumwntation....plus eavesdropping is difficult unlike rf
robheffo wrote 07/08/2015 at 23:27 point
Yeah, if time wasn't a factor then I would be definitely be looking into it. I know in my situation the idea would work because I am aiming about 45deg off the East/West path of the sun so a moderate tube will easily block out the sunlight from interfering with comms.
It just becomes a matter of reliable bandwidth.
greenaum wrote 11/18/2015 at 13:25 point
I'm surprised a white LED can be modulated so fast, since they generally use a blue LED chip, driving a yellow phosphor to produce white. You'd think residual phosphorescence would slow down it's decay time.
Still that's only white, other colours don't have the problem. And you can blast IR out all day long and nobody will even notice. Or any other colour, as long as it's directional, which is of course what you want.
