Household Electrically Enhanced Wet Scrubber
A household air purification unit for kitchens, labs, & smokers used to scrub fine particulates and VOC's out of the air.
For the past couple years, I Jimmy Locke have been developing a household air quality control device that can be used for scrubbing particulates and volatile organic compounds out of the air. This invention is of vital importance to households as indoor air quality is often very poor and not regulated by the EPA therefore it is up to the individual to ensure their air is clean. I originally invented this as a portable cooking ventilation appliance for kitchens that don't have outside venting range hoods. I believe this is the best application so far as the problem is wide spread.
As I developed the idea I soon found that there are several other household applications. Besides this being a generic air purifier, it is a great wood dust collector when paired with a dust cyclone as a pre-filter. This also can be used for scrubbing solder or welding fumes. Ultimately I would like to implement this as an appliance that allows one to smoke indoors without consequence.
What Is This?
This is my invention of an electrostaticly augmented cyclonic wet scrubber. It is a device that purifies the air by using water and electricity, without the use of a fabric filter. My vision is to leverage this technology to solve a variety of common household air quality problems. It would be awesome to use this technology to build centralized air cleaning units in homes, or stand alone air purifiers, or counter top kitchen range hoods, or laboratory recirculating fume hoods/extractors, or appliances that allow people to smoke indoors comfortably. Perhaps even a generic air-cleaning unit with multiple attachments that can do it all!
This invention is of vital importance to households as the air quality in households are not regulated by the EPA. More often than not, air quality inside a home is much worse than outside air due to trapped dust and allergens, smoke from cooking, chemicals from cleaning, and volatile organic compounds (VOC's) that leach from common building materials like carpet and paint. Serious chronic health conditions, ranging from asthma and bronchitis to lung cancer, can arise because of poor indoor air quality. Children and the elderly are most susceptible to developing these respiratory problems because of the amount of time they spend indoors.
My invention would be very valuable in the average household during the winter, when there is very little natural ventilation in the home to flush out indoor pollutants. It is also especially useful in areas like Beijing, where smog and PM2.5 air particles are constantly at high levels. Being an asthmatic myself and having a non-smoker friend recently being diagnosed with lung cancer, this invention is quite personal to me and I find indoor air quality a very pressing issue to address. Current wet scrubber technology is generally used in industrial settings to clean heavily polluted air, such as the exhaust of coal fired power plants and garbage incinerators. However, I strongly believe they need to be implemented into homes in one or more ways. My invention improves upon current wet scrubbing technology and makes it more accessible to the average household in both size and cost.
For the DIY enthusiast, my invention would be particularly useful in the workshop. Many DIY workshops produce dust, smoke, and harmful VOC's from activities ranging from soldering, welding, grinding, painting, cutting and staining wood, laser cutting, 3d printing, to chemistry experiments. The equipment required to clean such pollutants can get very pricey very fast. One of my goals is to make everything about my invention DIY, cheap, and yet have excellent results so the DIY enthusiast can make their own air cleaning device on a low budget. I built all of my prototypes as cheaply as possible and used second hand goods from Good Will and salvaged parts from electronic waste. Anyone on a tight budget can build one of these with parts sourced from a second hand store or a local hardware store.
Why Not Use A HEPA?
I chose wet scrubber technology over typical HEPA fabric filters for three reasons. One, because you can theoretically get the same results as a HEPA but don’t have to keep buying expensive filters - all you need is water and electricity. Second, wet scrubber technology can be used for applications where humid or oily particulates need to be removed, such as from cooking exhaust in the kitchen. HEPA fabric filters cannot handle humid or oil-laden air as it will get clogged and deteriorate. And third, wet scrubbers can absorb volatile organic compounds or gases that are soluble in water.
How Does It Work?
The key to my invention lies in the geometry of the wet scrubber and the use of electricity to boost its scrubbing power. My design is very scalable and can be implemented in a small form factor, providing good performance from a device the size of a counter top appliance.
It first ionizes the incoming particulate laden air via a high voltage pre-charger. This pre-charger...
  • 1 × 5 gallon bucket with lid 5 gallon bucket
  • 1 × Large Cylindrical Plastic Food Container Clear vacuum container
  • 1 × Tall Cylindrical Plastic Food Container Clear vacuum container
  • 2 × Schedule 40 ABS Pipe Cut two 4" sections
  • 3 × 1 1/4" PVC Coupler
View all 28 components
  • Finals Video
    Jimmy Locke10/26/2015 at 02:13 0 comments
    I'm so glad to have made it this far. I don't think I've ever worked this hard in my life. I feel so good to have completed this project! Thank you so much to Hackaday for the inspiration, the motivation, and the opportunity. Thank you to my wife who helped me so much at each step and to my parents who helped build it and to my friends and followers who gave lots of good input and encouragement. Thank you GOD!
  • Putting It all Together
    Jimmy Locke10/25/2015 at 01:26 1 comment
    Now it was time to assemble everything together, the wet scrubber, the electrostatic precipitator, and the activated carbon pods. I pondered for a while on what the order of the devices should be in. I knew I needed to keep the activated carbon as the last stage as it would gum up if it absorbed too many larger particulates. The question was whether to have the wet scrubber as the first or second stage. So far I had the electrical boosting at the first stage and the wet scrubber second. I decided to switch this and place the wet scrubber first as the wet scrubber could scrub all the fine particulates 2um and greater so the electrostatic precipitator could then take care of the ultra-fine particulates 2um and below to finally leave the activated carbon stage to absorb VOC's and any Ozone produced from the electrostatic precipitator.
    I simply routed the output of the wet scrubber to the input of the ESP via PVC pipe fittings.
    I then glued a sandwich container to the top of the ESP so the activated carbon pods could interface to them.
    Then I took four activated carbon pods and glued them together into one module, then I mounted it on top of the ESP.
    I decided to use the electrically charged versions of the activated carbon pods and connect the carbon pods to the same polarity as that of the ESP tube walls, this gave additional collection surface for ultra-fine particulates and indeed it did help! Here is the finished unit. A unit of this size could scrub all of the pollutants in my whole workshop or even my house if I connected it to the HVAC system.
    There were a few leaks that I needed to hot glue and seal but after connecting everything, the tests were amazing! It worked rather well. I turned the blower motor on and shot the fog machine directly into the input, the fog poored out the output end but when I turned the electricity on, the fog dissappeared! I could make smoke signals with this machine by turning on and off the ESP hahaha! If I turned the blower to full speed I could see some penetration with some fog coming out the end but it wasn't very significant. With more electricity I believe I could easily achieve 99% collection efficiency in a small unit as this! YAAAAAAY it works!
  • Tweaking the Problems
    Jimmy Locke10/25/2015 at 01:13 0 comments
    I learned two problems over the course of the last few days. One the flow of air needed to be laminar so that the fog could evenly be distributed to all of the tubes. And second the fog I was rather conductive and was slowly shorting out the electrostatic precipitator, particularly at the spot where the wire is suspended by a zip tie to the tube.
    To address the laminar flow problem, I created some baffles and some air distribution pipes in the bottom bucket. This required splitting the air flow intake to two pipes and drilling a series of holes in the pipes so the air would go in all directions more evenly.
    The holes were drilled so the air would enter on a horizontal plan then rise upwards.
    Then a series of grid like baffle was placed on top of the pipes to distribute the air even more. I made this out of a styrofoam frame that was cut out of my styrofoam cooler I found in the dumpster. I then glued some plastic canvas grid sheets onto the top and bottom of the frame. This created much more laminar flow before the air even entered the tubes.
    Concerning the shorting problem, I could measure a resistance between the central tube wire and the tube wall and this resistance would be reduced over each test I performed. I had to re-wire the entire back end cutting out all the zip ties which was a pain in the butt. I fixed this problem by adding more PVC pipe sections and suspending the central wire further from the tube walls using shish kabob skewers.
    After rewiring it looked like this.
    This would provide considerably more insulation as the electricity would have to travel from the tube wall, through the zip tie, to the length of the pipe and through a stick to get to the central wire. Indeed it worked!
    I also noticed that I could pump more energy into the precipitator by running another high voltage circuit in parallel with my existing circuit. This required building another pair of dual polarity cockroft walton multipliers. I ended up using another microwave oven transformer just to keep everything isolated but I believe I simply could have ran the multiplier stages in parallel to the single microwave oven transformer.
    I still think I can go to an even higher voltage and current as ESP's want to operate just below the arcing point. Unfortunately my router speed control kept blowing fuses when I attached more stages in parallel.
  • Building the ESP's (Electrostatic Precipitator) Part Two
    Jimmy Locke10/21/2015 at 08:48 0 comments
    Testing the tube ESP in my jury rigged setup showed promising results. It seemed to filter out almost all of the smoke that the fog machine produced. I then tried it by attaching the vacuum motor to get a higher air flow, I could see a little bit of smoke getting sucked out which was disappointing but it was much less smoke than if the ESP was turned off.
    It appeared that 15 pipes was not enough cross sectional area to slow the air down. I would go ahead and make 10 more pipes. Another trip to the hardware store!
    At the same time I wanted to prototype the electrified activated carbon idea that I had. I figured an easy way to implement my idea would be to use a stack of flat plastic containers. Each container would have its lid and bottom cut out of it to make a frame, and a screen glued in its place so air can flow through the stack of containers. Then every even container would be filled with activated carbon, and every odd container would contain an ionization grid.
    I went to shop for some cheap plastic containers and it seems that plastic sandwich containers would be just the right size not to mention very cheap.
    I went ahead to prototype the electrified activated carbon ESP assembly. I cut a square hole in the lids and bottom of all the containers then glued a aluminum screen to it. I then soldered a wire to the screen so I could electrify the activated carbon inside the container.
    To make the ionization grid, I simply zig zagged steel wire within the center of the container. With the help of my parents the other containers were all wired in an hour. I then filled the containers with activated carbon and made a stack of them.
    I attempted a small test by placing the vacuum motor on top to suck some fog through it while it was electrified.
    Unfortunately the test was a failure, the air did not have enough time to ionize as it passed axially through all of the containers. The particulate laden air needs a long dwell time to completely ionize so I would have to run more activated carbon containers in parallel rather than in series. This would amount to a lot of activated carbon however. Regardless of the test , I still like the use of sandwich containers to hold the activated carbon as it is highly modular and more or less can be used depending on the application. It also makes it easier to switch out old activated carbon for new.
    So far the tube electrostatic precipitator design worked the best so I went ahead and focused all of my efforts on trying to make this design better.
    I obtained two square buckets to house the tube ESP inside. With the help of my wonderful parents, I was able to build 10 more ESP pipe assemblies just last weekend. This brought me to a total of 25 pipes. The pipes would be packed together in a 10" by 10" square and fit inside between the two square buckets.
    If I were to do this all over, I would have picked square tubes as it was a pain to fill in all the gaps that were present between the round pipes.
    This week has been spent on assembling the ESP and tweaking it. I drilled many holes in the lid of the square bucket to fit the pipes.
    This turned out to be a bad method as It turned into a flimsy plastic net after all the holes were drilled.
    I then turned to a piece of plywood to interface the pipes to the buckets.
    This was a lot more rigid and could hold all of the ESP tubes tightly in a bunch. After the holes were drilled I had to insert the pipes.
    I then had to fill each gap between the pipes with a star shaped piece of wood and lots of guerrilla glue layer by layer.I finally got to the end.To be safe, I jammed some foam into the gaps between the pipes and dropped small pools of guerrilla glue in them to make it air tight. I also hot glued the edges to make everything sealed.I now had a near finished DIY tube electrostatic precipitator assembly!
    Next step is to test this and try and optimize it with the wet scrubber and activated carbon assemblies.
  • Building the ESP's (Electrostatic Precipitator) Part One
    Jimmy Locke10/20/2015 at 09:39 0 comments
    Two weekends ago I prototyped a test rig of my tube ESP (electrostatic precipitator) device. I first cut three of the 10ft length galvanized metal downspouts in to 2ft sections.
    To create a support structure for the wire that would run through the center of the pipes, I cut a 3" section of PVC pipe and zip tied it to the end of the metal pipe section.
    Then, using a shishkabob stick, I ran it through the PVC pipe and wrapped the wire around the stick so it can be tightened by spinning the stick, tightened much like a guitar string.
    On the other end I used a zip tie to suspend the wire in the center of the pipe.
    I did this 15 times and ended up with a bunch of pipe assemblies.
    To test the 2ft sections of pipes, I took two Styrofoam coolers I found in the dumpster and drilled holes in them. Since this was only a test, I spaced the holes far apart so an ESP can be assembled easily. In the actual version I would placed the pipes as close together as possible.
    I inserted all of the assembled pipes into the holes.
    I then wired all of the pipes together
    I then drilled a hole in the bottom cooler so my fog machine can shoot into it.
    Here is a video of an early test.
  • My Two DIY Electro-Static Precipitator (ESP) Designs
    Jimmy Locke10/20/2015 at 08:56 1 comment
    Tube ESP
    As I yet again went back to the drawing board, I decided I would pursue a tried and true method in designing an electrostatic precipitator to deal with the sub micron particles along with any new design I'd come up with just in case the new idea didn't work as planned.
    For my ionizing circuit, I was going to build a tube electrostatic precipitator that would either go before or after the wet scrubber as a separate stage. A tube electrostatic precipitator has a thin wire going axially through the center of a tube that is held at high voltage to produce corona that ionizes the air. Particulate laden air is passed through the tube and ionizes the particles such that it sticks to the walls of the tube.
    Although I intended to do this originally but was stopped by the fact that these devices produce Ozone, I would make the design such that it would minimize Ozone production by using positive corona and then absorb any produced Ozone into the scrubbing liquid as well as the activated carbon stage at the end. The Ozone absorbed into the scrubbing liquid will help sterilize it and help oxidize any VOC's that enter it, the remainder of the Ozone should be absorbed by the activated carbon stage.
    I purchased several round galvanized gutter downspout pipes from the hardware store and some steel wire. I rigged one of the pipes to run a single steel wire along the center of it and connected it to my high voltage circuit. As the pipe was energized, I shot the fog machine into one end. NO SMOKE CAME OUT THE OTHER END! As I turned the high voltage electricity off, the smoke started to pass through pipe. It was like magic! At last, I had a device that worked for sub micron particles!
    Now it was time to cut up the pipe into sections so I can fit it into a housing. I used a general guideline that there needed to be 200-800 ft^2 of collection surface per 1000acfm. I approximated that my vacuum motor is providing roughly 100cfm. If I cut the 2inch diameter 10ft length pipes into five 2ft lengths, I could use five pipes go give me 25 pipes total with one pipe section giving me a little over 1 sq ft each. The total square footage of the collection surface being about 25ft^2 for 25 pipes. Electrostatic precipitators are quite bulky!
    Electrified Activated Carbon ESP
    As I thought to figure out how to incorporate the activated carbon stage as well as shrink this device, a new design came to me. I could combine the activated carbon stage and the electrostatic precipitator stage into one. Since activated carbon naturally has a large surface area, why not electrify it and use this as the electrostatic precipitator? My idea was to have sectional containers of activated carbon that is charged to a high voltage seperated by a small distance from which in between the carbon sections are ionizing grids charged to an opposite polarity to provide corona and ionization. As particulate laden air passes through the ionizing grids, the particles should adhere to the electrified activated carbon which acts as a collection surface for both particulates and VOC's (including any Ozone produced).
    I thought to prototype this new electrified activated carbon design in addition to prototyping the tube electrostatic precipitator as I know at least this idea works reliably. Should one implementation fail, I could rely on the tried and true method.
  • Testing With Sub Micron Particles (Smoke)
    Jimmy Locke10/20/2015 at 08:21 1 comment
    Thank you HAD for allowing me to be in the finals! Truly a shock, a thrill, and an honor. Ever since the announcement I have been non-stop working to continue the development and testing where I left off on the last video. I only bit of time to write some project logs as I'm waiting for glue to dry.
    From where I left off... The first order of business was testing the two stage wet scrubber design with a large source of sub-micron particles. I'd like to thank the HAD community and my friends for providing me many great ideas on how to test my machine cheaply and how to detect sub micron particles --namely the use of smoke detectors as a cheap particle detector was simply brilliant.
    The first thing I bought were three smoke detectors two ionizing type and one photoelectric type. They were very cheap!
    My original intent was to probe inside to get a voltage reading from the photo or ionizing particle detectors but I soon found this was unnecessary.
    I needed to find a source of sub micron particles to test my machine that wasn't too dangerous. My friend suggested I use nano powder zinc dioxide that could be sourced online to make DIY sun creen but the thought of shooting nano-powder everywhere didn't seem safe at all --even with a resperator.
    Another friend gave me three commando smoke grenades to test my machine with!
    This is an all or nothing kind of test! I was going to save these babies when I got my machine finally working because if I set this off in my garage and the filter didn't work, I'd have a lot of explaining to do to my wife and neighbors... and fire department.
    Luckily as I was walking through the department store, a Halloween store opened up. Then something clicked with me. I can use a fog machine!
    Fog machines produce a huge quantity of sub micron particles (smoke) and it is also safe to use and breath. I bought a fog machine and quickly went home to test my machine.
    I filled the fog machine with fog juice, let it warm up, then shot it directly into the input of my two stage wet scrubber. What happened next was, well, exciting.
    Not only did my wet scrubber did basically nothing to filter any of the smoke, it filled my entire lab with smoke and set off all the smoke detectors that I just bought all at once including the one built into my lab. I ran around frantically trying to turn off all the smoke detectors. As I opened my garage, a huge smoke cloud went outside. Luckily none of my neighbors noticed.
    So it appears that the electrospray ionization effect wasn't nearly as great enough as I expected. I was quite sad that this did not work as I planned. I realized the scale and implementation was a bit off. I needed much more surface area and a lot more corona to sufficiently ionize the particulate laden air.
  • Artist Rendition of "Productized" Designed Look/Feel of Project
    Jimmy Locke09/21/2015 at 06:25 0 comments
    Here is what a consumer product implementation may look like. With the help of my wife, a sketchup model was produced of a counter top version of a wet scrubber recirculating hood. The rectangular hood would contain a centrifugal blower. The two stage electrified wet scrubber would exist in the central pillar, the cleaned air would exit at slits in the feet, directing air back into the hood to create an air blade "wall". This type of product form factor would be fitting for the kitchen and the laboratory.
  • HackadayPrize Semifinals Video Submission
    Jimmy Locke09/20/2015 at 10:40 0 comments
  • Redesigning and Rebuilding
    Jimmy Locke09/20/2015 at 09:19 0 comments
    I hit a few road blocks. I don't know how to measure performance below a 1um accuracy and I don't know how to ionize the incoming air without generating harmful Ozone. Walking around my living room with my hands in the air, my wife came to the rescue with a single sentance.
    "Why not use water to ionize the air?" she said.
    GENIUS! This led me to my current design. A two stage electrospray ionizing wet scrubber. Although I rebuilt the wet scrubber into a smaller form factor, I now had two wet scrubbers. I would use the first wet scrubber's liquid to charged the particulate laden air that passes through it; the particulates would be charged in a pseudo electrospray fashion. Then I would pipe the charged particulates into the second wet scrubber that is charged to an opposite polarity. Using water to ionize air would solve the Ozone problem as there would be no corona produced from the water spray. It was worth a shot! My original goal of making the whole unit smaller would have to wait, now this thing would become even more beastly! Muhahahahahahaha!
    I added an aluminum rod to the inside of the smaller wet scrubber acting as a charging pole for the scrubbing liquid.
    Next I simply stacked the second wet scrubber (the original prototype) on top of the smaller version and piped the output of the bottom scrubber into the inlet of the top scrubber.
    The top scrubber also has the same rod on the inside to charge its scrubbing liquid to the opposite polarity of that of the scrubber below it.
    I attached the clear domed lid, the vacuum motor, and the high voltage circuit.
    Both wet scrubbers were filled with salt water and had opposite high voltage applied to them. Here is a video of a quick test run.
View all 21 project logs
  • 1
    Step 1
    These instructions are to build exactly what I have prototyped. Since this technology is highly customizable, different containers or materials can be used to scale the device to whatever application needed. There is much room for creativity here.
    Cyclonic Self-Induced Spray Wetscrubber Instructions
    The wet scrubber is what is used to filter out fine particulates and some VOC's out of the air (fine meaning everything greater than 2um). The wet scrubber is comprised of two parts, the hollow walled tube assembly, and the wet scrubber housing. The hollow walled tube assembly is comprised of an inner tube that has inward and outward spiraling holes, an outer tube that covers the inward spiraling holes, an inlet pipe that connects to the outer tube, and a mist eliminator bowl.
    To build the wet scrubber section you'll need thick walled ABS or PVC pipe and several plastic containers: two to make a hollow walled tube, one to make the mist eliminator, and another larger one to house the hollow walled tube assembly. The housing bucket can be either a 5 gallon bucket or 3 gallon bucket depending on your application. The housing bucket will need to be about a foot high and wide enough to be able to fit a hollow walled tube in the center of it along with several inches of clearance.
    Hollow Walled Tube Assembly
    Lets begin by building the hollow walled tube. Take the 4" diameter ABS pipe and cut two 4" lengths from it. Then drill at least 6 rows of holes that spiral inwardly. This can be done by placing the tube section on a drill press such that the drill bit enters tangentially to the wall of the pipe. The number of holes must be greater than the total cross sectional area of the smallest air piping you will use. For example if I were to add up the space from all the little holes, it would be bigger than the cross sectional area of the air inlet pipe. For the other ABS pipe section, drill the holes to spiral in the opposite direction as that of the first ABS pipe section. This is is done so the air that enters the hollow walled tube will continue to spiral in the same direction as it exists the tube.
  • 2
    Step 2
    Next take a cylindrical plastic food storage container that has the same diameter as the 4" ABS pipe and cut the bottom off of it. You can also simply not cut the ABS pipe and keep it as one piece to form the inner wall of the hollow walled tube. I chose clear containers so I could see inside while it is operating. You will want the length of the hollow walled tube to be shorter than the wet scrubber housing (the bucket) such that the lid can fit on it and seal the wet scrubber housing.
    Then take a larger cylindrical plastic food storage container that is of larger diameter and cut out a 4" diameter hole out of the lid and the bottom such that the narrower cylindrical container can fit inside.Note that inserting the narrower container into the larger one creates a hollow walled tube. Now glue to lid of the larger container (which has a 4" hole in it and is now a ring) to the 4" ABS pipe section using hot glue or solvent.
  • 3
    Step 3
    Next an inlet port is cut out of the outer wall of the hollow walled tube (the larger container. I first cut a rough curve on a PVC pipe then butt it up against the tube and traced its profile to get the size of hole needed. Using a rotory tool, drill out the inlet hole to the hollow walled tube.Then glue a 1 1/4" PVC pipe to the oval hole to act as an inlet port.
View all 44 instructions
mubay_512 wrote 01/11/2018 at 09:48 point
Hello Jimmy. I am very interested in your project. I would like to finance your project and come up with final product.
damian_nygaard wrote 11/06/2017 at 19:59 point
Any updates since 2015?  I'd like to try this for a laser fume filter.
Chen Gu wrote 12/09/2016 at 00:24 point
Very cool project.  But have you considered any ways to quiet down the system without reducing efficiency and air flow volume?  Noise seems to be a major concern for a lot of household air filters.
spencerpeterson85 wrote 10/25/2015 at 03:50 point
Just finished reading through all the project logs. Great build! As I mentioned in my YouTube comment, I'm thinking of making something similar to filter fumes from my laser cutter. I noticed in one of your early logs that you had purchased some power supplies for ionization from eBay and you said they weren't all that great. I found this: http://www.amazing1.com/products/negative-ion-generator-115vac-input-18kv-output.html and was wondering if you'd recommend against it based off of your experience.
Jimmy Locke wrote 10/25/2015 at 04:22 point
Thank you sir! That ion generator looks considerably better than the unit I bought for 6 bucks.  I would be concerned with the amount of current the ionizer produces.  If you keep the air flow rather low, it may work.  The price isn't too bad to give it a shot and it is certainly a safer method than what I'm doing.
I haven't got around to measure how much current my system draws but I would guess I am drawing more than the specified 110mA.  Then again I'm filtering a ton of smoke.
Keith Olson wrote 10/06/2015 at 04:17 point
To detect the finest particles, you could use a standard ionizing air purifier hooked directly (and solely) to the output of your system, with a USB microscope looking at a (highly polished) section of the depositing plate, then let the system run for an extended period while a camera takes pictures at set intervals.  The resulting darkening of the pictures over time *should* give you a fairly good estimate of how well your filtration is doing.
Jimmy Locke wrote 10/06/2015 at 06:12 point
That is very creative!  When you say depositing plate do you mean the metal panels that are electrified to attract particulates?  I would imagine most of the particulate air would pass through the standard ionizer as those devices are optimized for very slow air flow rates so efficiency vs airflow for the off the shelf device would have to be calculated before quantifying darkness of the images.
Keith Olson wrote 10/06/2015 at 04:09 point
(Note: tl;dr comments, so this might have already been covered.)
For dust collecting, may I suggest using a 'Thien Baffle' (http://woodgears.ca/reader/jensen/) to *drastically* reduce the amount of dust entering the rest of the system.
Jimmy Locke wrote 10/06/2015 at 06:04 point
Thanks for suggestion!  Yes the scrubber is not intended to suck bulk wood dust directly but as a secondary stage for fine particulates.  Otherwise a mass of dust would clog the wet scrubber too quickly.  In the quarterfinals video I used a cyclonic separator to get rid of most of the large dust, a thein baffle would work just as well :)
RandyKC wrote 09/23/2015 at 22:44 point
This HAD.io project uses the pressure differential across a filter media to determine amount of pollution.
https://hackaday.io/project/5110-pollution-detecting-system
Jimmy Locke wrote 09/23/2015 at 21:27 point
Good point.  I'll look for the photo sensor kind then; no project of
mine is ever worth harming myself over.  I suppose if I get a
radioactive kind it can be used simply in the normal fashion to see
whether bulk smoke is getting through and sounding an alarm.  I don't
have to take it apart for that.
RandyKC wrote 09/23/2015 at 06:34 point
I was thinking of adding KOH to the water. NaCL will release Chlorine if it binds to a contaminant. I wonder if the ionizing additive you use can effect the capacity of the water to absorb the contaminant or the ability of the liquid to hold a positive vs negative charge.
To test for volatile organics, I would use indicator paper. For example to test for the removal of Acetic Acid, I would check the pH of the output.
To test for particles, my first thought is to get a smoke detector and look at the output through an oscilloscope. The sensitivity of the smoke detector will vary. Don't get the Americium-241 type that uses ionizing radiation use the photoelectric type. They aren't as sensitive, but if you're poking inside you can expose yourself to some alpha particles and make the TSA people nervous if you get on an airplane.
Another thought is the Halogen gas detectors sold at Lowe's and Home Depot to detect Natural gas. They also work on other gases such as gasoline vapor to a lessor or greater effect.
Jimmy Locke wrote 09/23/2015 at 17:34 point
Thank you for the great ideas!  I will definitely try the smoke detector idea as that is a quick and cheap way to test.  Is it possible to probe the sensor of radioactive smoke detector at terminals away from the actual piece of Americium?  There must be some sort of micro or analog level signal I could probe on the PCB.  I was reading the photosensor type requires a rather thick amount of smoke to register any reading.
I'm a bit hesitant to use KOH as I may have trouble disposing of the liquid afterwards and may be a bit dangerous to touch.  Another option I may try is to not use any salt or use baking soda.
I haven't done much as far as VOC filtering. That stage would require an activated carbon bed which I have prototyped but haven't optimized for the volume of air flow.
RandyKC wrote 09/23/2015 at 18:45 point
The ionizing smoke detector uses the plastic case as part of the shielding from the alpha particles. I really wouldn't mess with it unless you had a alpha particle geiger counter so you knew what you were exposing yourself to. M. Curie was brilliant but what she didn't know did hurt her.
