2018-05-16
05/17/2018 at 07:37 • 0 commentsThe URDF is very time consuming but its coming along nicely. I have added all joints and are now working on to make them work as in reality.
The wheels are working great and the visualization in RVIZ presents the reality very well.
I have also started to work with the IMU joint and the ability to visualize the rotation of the robot (pitch, roll,yaw). To got this working I am using robot_localization pkg (sensor_fusion) Here I am fusing Odom and IMU to odometry/filtered. The visualization is still not very good for the IMU and will need some more love -
2018-05-14
05/16/2018 at 05:45 • 0 commentsTonight I have begun building the robot's URDF for better and nicer visualization in RVIZ when driving around. I also hooked up the 9DOF to test and confirm its functionally .I am using the (SparkFun 9DoF Razor IMU M0 - SEN-14001) and it was not easy to get it to work over ROS, but finally it did
The URDF will be an exact copy of the real robot and I will mostly use combined STL´S files as meshes for the URDF.
![ROS Valify Urdf ROS Valify Urdf]()
ROS Valify Urdf -
2018-05-13
05/15/2018 at 12:09 • 1 commentToday I did the first test drive! Yey! One pulley still makes annoying sounds.
2018-05-09
05/09/2018 at 20:16 • 0 commentsTesting the drive system. I need to remake the pulleys because they are slipping. Otherwise everything works fine!
Small test video
2018-05-07
05/07/2018 at 21:07 • 0 commentsSo the last days I have been busy. All parts for the drive system was completed and tonight I finished the first test assembly of the drive system. Its a lot of parts for this part of the project and a lot of things need to be correct in order for a nice run. It took a bit of time to get it right and it was a lot of tinkering. ![]()
A quick video spinning the wheels:
2018-04-30
04/30/2018 at 20:44 • 0 commentsProject update:
Drive system assembly test. Everything fits perfectly. Some welding left and we are good to go :-)![]()
2018-04-26
04/27/2018 at 06:46 • 0 comments -
2018-04-25
04/25/2018 at 19:10 • 0 comments -
2018-04-24
04/24/2018 at 09:27 • 0 commentsFirst big body cover printed. The part came out great. Running PrimaSelect PETG Solidwhite at 240C. This print was printed with 0.6mm nozzle instead of the original 0.4mm. layers looks nice and even! This part was printed at 2 shells at 10% infill and print time landed on around 15h.
![First big body cover 3D printed. First big body cover 3D printed.]()
First big body cover 3D printed. ![First big body cover 3D printed. First big body cover 3D printed.]()
The motor brackets are ready and just some minor things left to be CNC milled. Then finally I can assemble the drive system
![CNC Milling motor brackets CNC Milling motor brackets]()
CNC Milling motor brackets ![a pair of CNC milled motor brackets a pair of CNC milled motor brackets]()
a pair of CNC milled motor brackets -
2018-04-21
04/21/2018 at 10:37 • 0 comments3D printing New front nose, ready in 1h. Hopefully everything fits perfect!
Robin Fröjd
