Build a linear CCD module (SPI-version) The 3D-printed CCD-box is for the LDO-version PCB (but the LDO part of the circuit does not necessarily need to be populated). Install a 1x6 pin header on the back of the board. [picture coming]
Print everything (box for the CCD, magnetic lid for the box, base for the rpi, sandwhiched-layer between nucleo and rpi).
Assemble the stuff: Install rpi at bottom with 20mm M3 screws (the holes in the rpi may need to be expanded): The install screws in the sandwhich-layer (still 20mm M3's):Place it over the rpi: Install the cable to connect GPIOs on the rpi (the purple wire is connected to GPIO22):Install the nucleo: Finally, connect the nucleo and the CCD: [picture coming]
