​Nyan Board by Radomir Dopieralski
A project log for Me building projects from hackaday.io
This is where I build and talk about projects designed by the great people of this community.
davedarkodavedarko 10/31/2015 at 11:1113 Comments
#Nyan Board by @Radomir Dopieralski
[UPDATE] Video and code added
So this should be an easy one, right? Oh how I failed. I'm still not getting sounds out of it, after I played around with libraries and different Versions of arduino. It's always tones and timers that get me.
I first thought the pads next to the attiny45/85 where a pullup resistor - d'oh. Of course it didn't do anything. Now it at least blinks.
To fit on an attiny45 I had to change the code a bit.
this code works, see the comments:
const int LENGTH = 27;
const int NOTES[] PROGMEM = {
    65, 67, 70, 67, 74, 74, 72, 65, 67, 70, 67, 72, 72, 70, 69, 67, 65, 67, 70,
    67, 70, 72, 69, 65, 65, 72, 70
const int DURATIONS[] PROGMEM = {
    25, 25, 25, 25, 75, 75, 15, 25, 25, 25, 25, 75,
    75, 75, 25, 5, 25, 25, 25, 25, 100, 5, 75, 25,
    100, 5, 100, 200
void play() {
    float bps = (60.0 / 120) * 1000.0;
    for (int i = 0; i < LENGTH; ++i) {
        int note = pgm_read_word_near(NOTES + i);
        int duration = pgm_read_word_near(DURATIONS + i);
        int hertz = (int) (pow(2.0, ((note - 69.0) / 12.0)) * 440);
        tone(4, hertz, (long) (duration * bps / 100) - 10);
        delay((long) (duration * bps / 100));
        toggle_eyes();
void toggle_eyes() {
    PORTB ^= ( 1 << PB3 );
void setup() {
    DDRB = ( 1 << PB3 );
    DDRB = ( 1 << PB4 );
void loop() {
    play();
#include "pitches.h"
#include <avr/pgmspace.h>
const int FREQ[]  = {
    REST, NOTE_AS4, NOTE_AS5, NOTE_B4, NOTE_B5, NOTE_CS5, NOTE_CS6, NOTE_D5,
    NOTE_DS4, NOTE_DS5, NOTE_DS6, NOTE_E4, NOTE_E5, NOTE_E6, NOTE_FS4,
    NOTE_FS5, NOTE_GS4, NOTE_GS5,
const signed char INTRO_NOTES[] PROGMEM = {
9, 12, -15, -4, 9, 12, 15, 4, 6, 10, 6, 2, -4, -15, 9, 12, -15, -4, 6, 2,
4, 6, 13, 10, 13, 4, 0
const signed char MELODY_NOTES[] PROGMEM = {
-15, -17, 9, 9, 0, 3, 7, 5, 3, 0, -3, -5, -7, 7, 5, 3, 5, 9, 15, 17, 9, 15, 5,
9, 3, 5, 3, -9, -15, 17, 9, 15, 5, 9, 3, 7, 9, 7, 5, 3, 5, -7, 3, 5, 9, 15, 5,
9, 5, 3, -5, -3, -5, -15, -17, 9, 9, 0, 3, 7, 5, 3, 0, -3, -5, -7, 7, 5, 3, 5,
9, 15, 17, 9, 15, 5, 9, 3, 5, 3, -9, -15, 17, 9, 15, 5, 9, 3, 7, 9, 7, 5, 3, 5,
-7, 3, 5, 9, 15, 5, 9, 5, 3, -5, -3, -5, -3, 14, 16, -3, 14, 16, 3, 5, 9, 3,
12, 9, 12, 15, -3, -3, 14, 16, 3, 14, 12, 9, 5, 3, 14, 8, 11, 14, -3, 14, 16,
-3, 14, 16, 3, 3, 5, 9, 3, 14, 16, 14, -3, 3, 1, 3, 14, 16, 11, 12, 9, 12, 15,
-3, -1, -3, 14, 16, -3, 14, 16, 3, 5, 9, 3, 12, 9, 12, 15, -3, -3, 14, 16, 3,
14, 12, 9, 5, 3, 14, 8, 11, 14, -3, 14, 16, -3, 14, 16, 3, 3, 5, 9, 3, 14, 16,
14, -3, 3, 1, 3, 14, 16, 3, 12, 9, 12, 15, -3, -5
#define BEEP_PIN 4
#define LED_PIN 3
#define SPEED 1500
    static bool blink = false;
    digitalWrite(LED_PIN, blink);
    blink = !blink;
void play(const signed char *notes, const unsigned int length) {
    for (unsigned int n = 0; n < length; n++) {
        signed char f = pgm_read_word_near(notes+n);
        int d;
        if (f < 0) {
            d = SPEED / 8;
            f = -f;
        } else {
            d = SPEED / 16;
        tone(BEEP_PIN, FREQ[f], d);
        delay(1.3 * d);
        noTone(BEEP_PIN);
        toggle_eyes();
void setup() {
    play(INTRO_NOTES, 26);
void loop() {
    play(MELODY_NOTES, 216);
deʃhipu wrote 11/09/2015 at 22:13 point
I updated the code at bitbucket to use progmem too: https://bitbucket.org/thesheep/nyan/src/tip/alternate/alternate.ino
deʃhipu wrote 11/02/2015 at 10:50 point
How about something like:
        long now = millis();
        int f = pgm_read_word_near(notes+n);
        int d;
        if (f < 0) {
            d = (SPEED / 8) * 1.3;
            f = -f;
        } else {
            d = (SPEED / 16) * 1.3;
        while (millis() < now + d) {}
        noTone(BEEP_PIN);
        toggle_eyes();
davedarko wrote 11/02/2015 at 12:41 point
nopes, same result.
deʃhipu wrote 10/31/2015 at 12:09 point
The original core I used was https://code.google.com/p/arduino-tiny/ at 1Mhz. You are not getting any sound at all, or just distorted sounds?
davedarko wrote 10/31/2015 at 13:27 point
I finally got sound! I've imported the arduino-tiny stuff into my sketch folder and it works on an attiny45 with arduino 1.6.5! Have you changed the song to Rick Astleys "Never gonna give you up"?
deʃhipu wrote 10/31/2015 at 14:20 point
davedarko wrote 10/31/2015 at 20:46 point
it's recognizable, but I have some bumps in the song.
deʃhipu wrote 11/01/2015 at 22:22 point
Hmm, interesting, I wonder what that may be. Note how the eyes also blink when it stutters, so it's not just the tone generator -- it looks like the whole chip is pausing. Weird. Maybe the delay() function has a bug?
davedarko wrote 11/01/2015 at 22:42 point
I changed the program a bit to fit on an attiny45 - I've put the arrays to progmem. Maybe it's not reading fast enough? I'll post the code tomorrow, maybe you could check it on your attiny85.
davedarko wrote 11/02/2015 at 10:17 point
@Radomir Dopieralski - I've added the code on the bottom.
deʃhipu wrote 11/02/2015 at 10:26 point
That may be. How about you read the next note into a variable before doing the delay()?
deʃhipu wrote 11/04/2015 at 22:21 point
Wait, doesn't it get stuck on the negative notes?
Maybe try making f a signed char, not an int?
davedarko wrote 11/05/2015 at 10:59 point
!!! that's it !!!
