#Nyan Board by @Radomir Dopieralski
[UPDATE] Video and code added
So this should be an easy one, right? Oh how I failed. I'm still not getting sounds out of it, after I played around with libraries and different Versions of arduino. It's always tones and timers that get me.
I first thought the pads next to the attiny45/85 where a pullup resistor - d'oh. Of course it didn't do anything. Now it at least blinks.
To fit on an attiny45 I had to change the code a bit.
this code works, see the comments:
const int LENGTH = 27;
const int NOTES[] PROGMEM = {
65, 67, 70, 67, 74, 74, 72, 65, 67, 70, 67, 72, 72, 70, 69, 67, 65, 67, 70,
67, 70, 72, 69, 65, 65, 72, 70
const int DURATIONS[] PROGMEM = {
25, 25, 25, 25, 75, 75, 15, 25, 25, 25, 25, 75,
75, 75, 25, 5, 25, 25, 25, 25, 100, 5, 75, 25,
100, 5, 100, 200
void play() {
float bps = (60.0 / 120) * 1000.0;
for (int i = 0; i < LENGTH; ++i) {
int note = pgm_read_word_near(NOTES + i);
int duration = pgm_read_word_near(DURATIONS + i);
int hertz = (int) (pow(2.0, ((note - 69.0) / 12.0)) * 440);
tone(4, hertz, (long) (duration * bps / 100) - 10);
delay((long) (duration * bps / 100));
toggle_eyes();
void toggle_eyes() {
PORTB ^= ( 1 << PB3 );
void setup() {
DDRB = ( 1 << PB3 );
DDRB = ( 1 << PB4 );
void loop() {
play();
#include "pitches.h"
#include <avr/pgmspace.h>
const int FREQ[] = {
REST, NOTE_AS4, NOTE_AS5, NOTE_B4, NOTE_B5, NOTE_CS5, NOTE_CS6, NOTE_D5,
NOTE_DS4, NOTE_DS5, NOTE_DS6, NOTE_E4, NOTE_E5, NOTE_E6, NOTE_FS4,
NOTE_FS5, NOTE_GS4, NOTE_GS5,
const signed char INTRO_NOTES[] PROGMEM = {
9, 12, -15, -4, 9, 12, 15, 4, 6, 10, 6, 2, -4, -15, 9, 12, -15, -4, 6, 2,
4, 6, 13, 10, 13, 4, 0
const signed char MELODY_NOTES[] PROGMEM = {
-15, -17, 9, 9, 0, 3, 7, 5, 3, 0, -3, -5, -7, 7, 5, 3, 5, 9, 15, 17, 9, 15, 5,
9, 3, 5, 3, -9, -15, 17, 9, 15, 5, 9, 3, 7, 9, 7, 5, 3, 5, -7, 3, 5, 9, 15, 5,
9, 5, 3, -5, -3, -5, -15, -17, 9, 9, 0, 3, 7, 5, 3, 0, -3, -5, -7, 7, 5, 3, 5,
9, 15, 17, 9, 15, 5, 9, 3, 5, 3, -9, -15, 17, 9, 15, 5, 9, 3, 7, 9, 7, 5, 3, 5,
-7, 3, 5, 9, 15, 5, 9, 5, 3, -5, -3, -5, -3, 14, 16, -3, 14, 16, 3, 5, 9, 3,
12, 9, 12, 15, -3, -3, 14, 16, 3, 14, 12, 9, 5, 3, 14, 8, 11, 14, -3, 14, 16,
-3, 14, 16, 3, 3, 5, 9, 3, 14, 16, 14, -3, 3, 1, 3, 14, 16, 11, 12, 9, 12, 15,
-3, -1, -3, 14, 16, -3, 14, 16, 3, 5, 9, 3, 12, 9, 12, 15, -3, -3, 14, 16, 3,
14, 12, 9, 5, 3, 14, 8, 11, 14, -3, 14, 16, -3, 14, 16, 3, 3, 5, 9, 3, 14, 16,
14, -3, 3, 1, 3, 14, 16, 3, 12, 9, 12, 15, -3, -5
#define BEEP_PIN 4
#define LED_PIN 3
#define SPEED 1500
static bool blink = false;
digitalWrite(LED_PIN, blink);
blink = !blink;
void play(const signed char *notes, const unsigned int length) {
for (unsigned int n = 0; n < length; n++) {
signed char f = pgm_read_word_near(notes+n);
int d;
if (f < 0) {
d = SPEED / 8;
f = -f;
} else {
d = SPEED / 16;
tone(BEEP_PIN, FREQ[f], d);
delay(1.3 * d);
noTone(BEEP_PIN);
toggle_eyes();
void setup() {
play(INTRO_NOTES, 26);
void loop() {
play(MELODY_NOTES, 216);
I updated the code at bitbucket to use progmem too: https://bitbucket.org/thesheep/nyan/src/tip/alternate/alternate.ino
How about something like:
long now = millis();
int f = pgm_read_word_near(notes+n);
int d;
if (f < 0) {
d = (SPEED / 8) * 1.3;
f = -f;
} else {
d = (SPEED / 16) * 1.3;
while (millis() < now + d) {}
noTone(BEEP_PIN);
toggle_eyes();
nopes, same result.
The original core I used was https://code.google.com/p/arduino-tiny/ at 1Mhz. You are not getting any sound at all, or just distorted sounds?
I finally got sound! I've imported the arduino-tiny stuff into my sketch folder and it works on an attiny45 with arduino 1.6.5! Have you changed the song to Rick Astleys "Never gonna give you up"?
Maybe ;)
Try this for the original one: https://bitbucket.org/thesheep/nyan/src/tip/alternate/alternate.ino
it's recognizable, but I have some bumps in the song.
Hmm, interesting, I wonder what that may be. Note how the eyes also blink when it stutters, so it's not just the tone generator -- it looks like the whole chip is pausing. Weird. Maybe the delay() function has a bug?
I changed the program a bit to fit on an attiny45 - I've put the arrays to progmem. Maybe it's not reading fast enough? I'll post the code tomorrow, maybe you could check it on your attiny85.
@Radomir Dopieralski - I've added the code on the bottom.
That may be. How about you read the next note into a variable before doing the delay()?
Wait, doesn't it get stuck on the negative notes?
Maybe try making f a signed char, not an int?
!!! that's it !!!
