Light Alarm Clock
Standalone alarm clock that will fade a light on and then back off.
Especially in the winter months I find it hard to get out of bed in the morning. Usually I don't even get to see the sun during the week other than my lunch break...
So, to help solve this problem I made myself a little alarm clock that will fade a light on when I set the alarm and then turn the light back off again automatically.
Because making sure a dimmable AC circuit will work is hard (plus I would have to actually get a dimmable light then...), the light alarm clock is based around a 12V DC LED lamp.
A nodeMCU connects to NTP over wifi to keep in sync and calibrate the time / date. There is no RTC even though it would be simple to add in the future (again, don't have one).
Current software is pretty bad, but does all I need it to for now.
  • 1 × LED Lamp Because fading DC lights is easy
  • 1 × NodeMCU Overkill++
  • 1 × Power N Channel FET
  • 1 × 7805 Or other 5V PSU
  • Good enough for now!
    gannon • 11/18/2015 at 01:52 • 0 comments
    The 3.3V logic from the NodeMCU wasn't enough to fully turn on my FET, so I have rigged up a simple level shifter using a diode and resistor. The light is actually fairly bright now rather than the dim glow it used to be.
View project log
TheotherMike wrote 09/22/2016 at 19:30 • point
How fast is that !?! :-) Thank you so much !
TheotherMike wrote 09/22/2016 at 19:26 • point
Could you please give us the code for rebuilding it?
gannon wrote 09/22/2016 at 19:28 • point
The code is available on github at https://github.com/mswillia/Light-Alarm
