10000 Volt Power Supply
01/11/2016 at 02:28 • 2 commentsMy diodes arrived. Using a piece of recycled epoxy board I installed 40 1000 volt diodes in 4 series elements creating this Bridge Diode Assembly.
90% Complete CO2 Laser Project
11/25/2015 at 02:41 • 0 commentsThe laser has been mounted on the base.
Changes and Modifications
11/16/2015 at 00:01 • 0 commentsNov. 15
> Replaced Nylon 1/2" Plug with Brass. Heat conduction and better electrical connection. >
