Firstly I hooked up the joystick as shown in the schematic. The two 10k resistors coming from Joystick X and Y are there so when the digital GPIO is sinked to GND the Analog input is not also sinked completely to ground. to check for X GPIO 13 is set to floating and GPIO 14 is set to GND. using those 2 resistors along the voltage at the ADC will be half of what is coming from the Joystick X which will be a maximum of 1.65V. Since the ADC will only read to a maximum of 1 Volt, this voltage needs to be brought down even more. An additional 10K resistor is used to bring the voltage down even further. Ideally this should be a smaller value but in testing 10K seemed to be adequate and this further brought down the BOM.
Using this code I was able to make a function to calibrate the joystick by finding it's maximum and minimum values for both the X and Y and then creating functions for getting the X and the Y values.
int joystick_xmax = 1023;
float joystick_xmult = 1;
int joystick_ymax = 1023;
float joystick_ymult = 1;
static void calibrate()
int cnt = 0;
int xmax = 0;
int xmin = 1023;
int ymax = 0;
int ymin = 1023;
while(cnt < 4)
int jx = joystick_xmax-get_joystick_x();
int jy = joystick_ymax-get_joystick_y();
if((cnt % 2 == 0) && jx < 450)
cnt++;
if((cnt % 2 == 1) && jx > 800)
cnt++;
xmax = max(xmax, jx);
xmin = min(xmin, jx);
ymax = max(ymax, jy);
ymin = min(ymin, jy);
joystick_xmax = xmax;
joystick_xmult = 1023.0/(xmax - xmin);
joystick_ymax = ymax;
joystick_ymult = 1023.0/(ymax - ymin);
static unsigned int get_joystick_x()
pinMode(14,INPUT);
pinMode(13,OUTPUT);
digitalWrite(13,LOW);
return (unsigned int)max(0, min(1023,((joystick_xmax-analogRead(A0))*joystick_xmult)));
static unsigned int get_joystick_y()
pinMode(13,INPUT);
pinMode(14,OUTPUT);
digitalWrite(14,LOW);
return (unsigned int)max(0, min(1023,((joystick_ymax-analogRead(A0))*joystick_ymult)));
}Here are some videos of me testing the circuits.
Bread-boarding the circuit.
OLED pong ported over to it using the joystick.
Overview of the fully featured game module. Will be creating PCBs for it soon.
Daniel Johnson
Stefan-Xp
Richard Hogben
MasterOfNull
Hey this is pretty clever
