Hackaday.io Hackaday.io
Sign up Log in
NRF24L01 remote project
throwing stuff from eBay I hoarded at a project to control my projects
davedarkodavedarko
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.6k views
4 comments
3.7k followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
3.6k
4
3.7k
14
Team (1)
  • davedarkodavedarko
Join this project's team
  • range
ongoing project
nrf24l01 arduino joystick Remote control rc
Related lists
Remote Controllers
Remote Controllers
Nrf24l01 projects
Interesting projects that use the nrf24l01 module.
This project was created on 11/14/2015 and last updated 7 years ago.
Description
should also add BT functions plus the NRF24L01 modules. Works on 3.3V
Project Logs
Collapse
  • powering
    davedarko • 11/16/2015 at 15:00 • 12 comments
    https://www.pololu.com/product/2122
    Since this is supposed to be portable, I want to throw in a LiPo battery, but everything runs on 3.3V. While searching for step-up/step down converters I found the pololu.com S7V8F3. I've bought one some time ago and I'll just throw it in, instead of using a booster to 5V and a 1117 to drop it down again.
    Should have stayed with 5Vs, now that I'm thinking about that. Meh.
  • first days of fiddling
    davedarko • 11/14/2015 at 23:56 • 0 comments
    Three things I could rant about:
    1. I forgot that the Arduino is 3.3V and 8MHz
    2. the OLED displays I once bought had no reset circuit - fixed by adding a 10k resistor and 100nF cap, see: http://rayvenn.alnet.com.ua/2013/08/crius-oled-display-fix/
    3. the mounting holes of the pcbs are designed off center from the joystick - fixed case with dremel
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
K.C. Lee wrote 11/17/2015 at 00:30 • point
I hope you are using something else for the BT connectivity.  Due to hardware limitations, they can only broadcast.  i.e. you can certainly see them showing up, but the nRF24 modules cannot connect as BT devices
See here: http://dmitry.gr/index.php?r=05.Projects&proj=11. Bluetooth LE fakery
As for the real BT modules from China, my impression is that you'll need something with the HID profile.  The regular BT ones are only for serial port.  :(
davedarko wrote 11/17/2015 at 06:47 • point
I've only heard of nrf24 imitating bluetooth beacons before. Plan was to throw in a classic hc05 BT module.
davedarko wrote 11/17/2015 at 06:50 • point
serial is fine, I want similar package structures to be send to my "robots". BT would be nice, since #R8-D8 - a distant relative of R2-D2 uses that and I could also use my phone at some point, If I find the time to get into coding android apps.
Craig Hissett wrote 11/15/2015 at 21:47 • point
Another awesome one Dave!
Most DIY controllers i see that have a screen are huge; Arduino Unos, big screens, loads of buttons etc.
It's really, really nice to see such a compact controller that has all of the control I'd ever need without losing the feedback screen.
Cant wait to see how this one develops!
ESP8266 SMS Garage Alert system using a RCW-0001 Micro Ultrasonic Sensor and a Webhook (IFTTT.com and IFTTT android app)
Project Owner Contributor
SMS Garage Alert system using an Ultrasonic sensor
paul-gPaul G.
The 2017 Hackaday Prize
A low cost, open-source, universal-like remote control system that translates the user's head poses into commands to electronic devices.
TV Remote Control based on Head Gestures
cassio-batistaCassio Batista
An open hardware / open software vibrator, using a Trinket Pro (pro version) or a Digispark (mini version).
Digivibe
welsh-mulletWelsh Mullet
5 stage coilgun to fire 1/4" ball bearings
5 stage coilgun
matthew-james-bellafaireMatthew James Bellafaire
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "NRF24L01 remote project", please tell us the reason.
Send message
Remove Member
